[postgis-tickets] [PostGIS] #4700: Add more geography functions
trac at osgeo.org
Mon Jun 8 06:20:01 PDT 2020
Reporter: vogg | Owner: pramsey
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 2.3.x
Resolution: wontfix | Keywords: geography
Changes (by robe):
* status: new => closed
* resolution: => wontfix
* milestone: => PostGIS 3.1.0
Comment:
@vogg,
Sadly I'm going to have to dismiss this as a wontfix.
The reason we didn't bother with the trivial functions for geography is
because it would balloon up our function list and would also require
adding additional overloads to prevent the
"ambiguous function"
issue when people use text.
That said there is a feature in PostgreSQL mentioned in #postgis irc
channel (by RhodiumToad), I forget the date, that would possibly allow us
to better control auto casting in functions for geometry and geography.
This was discussed in IRC a while back. That we could take advantage of
the category feature of type - https://www.postgresql.org/docs/12/sql-
createtype.html
Unfortunately I think it might need us to redefine as I don't think there
is an alter type for that.
which would allow reuse of geometry functions in geography without having
to create parallel versions of them.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4700#comment:2>
