[postgis-tickets] [PostGIS] #4701: Travis: Add build based on PG REL_13_STABLE
trac at osgeo.org
Mon Jun 8 06:54:33 PDT 2020
Reporter: Algunenano | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: master
Keywords: |
The new branch is now available (REL_13_STABLE) so we should create a new
build image with that (and keep the one PG master/HEAD).
This image should build against latest **stable** releases of other
dependencies (GEOS, GDAL and so on) which means it will hit the same
errors as #4673
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4701>
