[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.1-16-g10c9412
git at osgeo.org
git at osgeo.org
Mon Jun 8 09:29:51 PDT 2020
the project "PostGIS".
The branch, stable-3.0 has been updated
via 10c94128723a8773481d5e6eeca2215a78bb151a (commit)
from 0717e6c8de1101548e860989bdfc7d6c7f1690a2 (commit)
revisions in full, below.
commit 10c94128723a8773481d5e6eeca2215a78bb151a
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Jun 8 09:29:45 2020 -0700
Legacy ST_Locate_Between_Measures is wrong, Closes #4702
diff --git a/NEWS b/NEWS
index 5619c63..4b029d9 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,7 @@ PostGIS 3.0.2
- #4652, Fix several memory related bugs in ST_GeomFromGML (Raúl Marín)
- #4661, Fix access to spatial_ref_sys with a non default schema (Raúl Marín)
- #4670, ST_AddPoint: Fix bug when a positive position is requested (Raúl Marín)
+ - #4702, Legacy ST_Locate_Between_Measures is wrong (Kaplas80)
PostGIS 3.0.1
diff --git a/postgis/legacy.sql.in b/postgis/legacy.sql.in
index 6a720dd..d750541 100644
--- a/postgis/legacy.sql.in
+++ b/postgis/legacy.sql.in
@@ -2056,7 +2056,7 @@ CREATE OR REPLACE FUNCTION ST_line_locate_point(geom1 geometry, geom2 geometry)
-- Deprecation in 2.0.0 replaced by ST_LocateBetween
CREATE OR REPLACE FUNCTION ST_locate_between_measures(geometry, float8, float8)
RETURNS geometry AS
- 'SELECT ST_LocateBetween($1, $2, $2);'
+ 'SELECT ST_LocateBetween($1, $2, $3);'
LANGUAGE 'sql' IMMUTABLE STRICT;
-- Availability: 1.2.2
Summary of changes:
NEWS | 1 +
postgis/legacy.sql.in | 2 +-
2 files changed, 2 insertions(+), 1 deletion(-)
hooks/post-receive
