[postgis-tickets] [PostGIS] #4705: pgsql2shp - Pg field column in mapping file incorrectly compared with the name of the dbf field name
PostGIS trac at osgeo.org
Wed Jun 17 02:24:35 PDT 2020
  Reporter:  zezzagio       |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:
 Component:  loader/dumper  |    Version:  3.0.x
Resolution:                 |   Keywords:
Comment (by zezzagio):
 Yes, I saw that; not sure it's enough. The parameter $custom_opts is not
 passed on, nor is readed directly from run_dumper_and_check_output in
 mfile_mapping.txt.
 I'm checking, anyway.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4705#comment:5>
