[postgis-tickets] [PostGIS] #4705: pgsql2shp - Pg field column in mapping file incorrectly compared with the name of the dbf field name
trac at osgeo.org
Thu Jun 18 03:01:22 PDT 2020
Reporter: zezzagio | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone:
Component: loader/dumper | Version: 3.0.x
Resolution: | Keywords:
Comment (by zezzagio):
I see no easy way to test this feature with the current test tool.
If a <input>.shp.expected exists, the sub run_dumper_and_check_output is
indeed called, without the -m parameter; and would fail (that's a start),
if a .dbf.expected file was compared with the result, which is not. Only
the .shp.expected is considered.
The sub run_dumper_test is more promising, and seems to compare all the
shape files. It is called if a ${TEST}.dmp file exists, from which it
reads the parameters; but only as the last parameter of pgs1l2shp, that is
the [table|query] argument. This goes after the [database] argument in the
call, thus it can't be used to pass the -m option.
Modifying run_dumper_test in order to take in account the custom options
is not a big thing, of course, but I'm not very confident to be able to do
it without breaking something.
I can investigate further, if you want, and propose something. Not sure
how much time it will take.
I estimate that this bug is present al least from version 2.5 (possibly
generated from some refactoring.) Having survived so long, I think, does
mean this is not a very used feature (or maybe the 10 characters limit is
not that low after all.) The whole shape file thing, I think, is something
we have all been hoping for a long time to get rid of (perhaps the thing
to do could be pgsl2spatalite or pgsql2gpkg.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4705#comment:6>
