[postgis-tickets] [PostGIS] #4705: pgsql2shp - Pg field column in mapping file incorrectly compared with the name of the dbf field name
trac at osgeo.org
Fri Jun 19 01:56:22 PDT 2020
Reporter: zezzagio | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone:
Component: loader/dumper | Version: 3.0.x
Resolution: | Keywords:
Comment (by strk):
> I don't like very much that my email address is published; is there
> any way to anonymize it?
I guess you can just tweak it to your liking, maybe just use your
OSGeo UserID ?
> Gis data without srid is something that I think would never have
> occurred to me.
It's just to keep the test smaller, given you didn't provide
an expected .prj file..
> Yes, it was "return 0", wich by chance caused an error state, because
> "Can't return outside a subroutine"; I translated it blindly into
> "exit 0", which is the right way to do it wrong.
I see, yes, it should probably be a "next" or "exit 1" there.
Or just drop the line, as it's the last thing done, and fail()
will count the failure anyway.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4705#comment:14>
