[postgis-tickets] [PostGIS] #4705: pgsql2shp - Pg field column in mapping file incorrectly compared with the name of the dbf field name
trac at osgeo.org
Fri Jun 19 01:37:03 PDT 2020
Reporter: zezzagio | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone:
Component: loader/dumper | Version: 3.0.x
Resolution: | Keywords:
Comment (by zezzagio):
Replying to [comment:12 strk]:
> Please for proper attribution use the correct author for your commits
though, with a valid email.
I don't like very much that my email address is published; is there any
way to anonymize it?
> 1. You don't need a SRID for the data (will just skip .prj creation)
Gis data without srid is something that I think would never have occurred
to me.
> 3. I dubt you want to exit 0 (succes) when PostGIS object count test
fails
Yes, it was "return 0", wich by chance caused an error state, because
"Can't return outside a subroutine"; I translated it blindly into "exit
0", which is the right way to do it wrong.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4705#comment:13>
