[postgis-tickets] [PostGIS] #4705: pgsql2shp - Pg field column in mapping file incorrectly compared with the name of the dbf field name
trac at osgeo.org
Sun Jun 21 01:46:44 PDT 2020
Reporter: zezzagio | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone:
Component: loader/dumper | Version: 3.0.x
Resolution: | Keywords:
Comment (by strk):
Git work is great, but someone will need to double check this because
the header file also says that function wants the PG name, not the DBF
name:
const char *colmap_dbf_by_pg(colmap *map, const char *pgname);
const char *colmap_pg_by_dbf(colmap *map, const char *dbfname);
Those signatures are in loader/shpcommon.h, lacking a comment.
The help output from shp2pgsql says the format is:
COLUMNNAME DBFFIELD1
AVERYLONGCOLUMNNAME DBFFIELD2
So we have the PostgreSQL column name on the left and the
DBF field name on the right.
The _same_ format is expected by pgsql2shp
(yes, key on the right in this case).
Is the code doing that ?
You are changing this:
- const char *mapped = colmap_dbf_by_pg(&state->column_map, dbffieldname);
+ const char *mapped = colmap_dbf_by_pg(&state->column_map, pgfieldname);
Does not seem to match with parameter names in signature...
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4705#comment:19>
