[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-139-g3334fd0
Mon Jun 22 10:37:52 PDT 2020
the project "PostGIS".
       via  3334fd0675c98c79a6a8527a05fc0e8c4c371835 (commit)
       via  b3ae6aadc804a98dc53727b5554bffd778e402b8 (commit)
      from  a2557be05fba0ed47ddd3dbb7dcf83b334581e65 (commit)
revisions in full, below.
commit 3334fd0675c98c79a6a8527a05fc0e8c4c371835
Author: Giovanni Zezza <OSGeo UserID: zezzagio>
Date:   Sat Jun 20 15:13:34 2020 +0200
    Corrected pgsql2shp for -m option; added test
    Postgres field column in mapping file was incorrectly compared with the name of the dbf field
    Closes #4705
diff --git a/loader/pgsql2shp-core.c b/loader/pgsql2shp-core.c
index 1596dc2..06226e9 100644
--- a/loader/pgsql2shp-core.c
+++ b/loader/pgsql2shp-core.c
@@ -1536,7 +1536,7 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
 		 * use this to create the dbf field name from
 		 * the PostgreSQL column name */
-			const char *mapped = colmap_dbf_by_pg(&state->column_map, dbffieldname);
+			const char *mapped = colmap_dbf_by_pg(&state->column_map, pgfieldname);
 			if (mapped)
 				strncpy(dbffieldname, mapped, 10);
diff --git a/regress/core/Makefile.in b/regress/core/Makefile.in
index bf2c851..b9df38b 100644
--- a/regress/core/Makefile.in
+++ b/regress/core/Makefile.in
@@ -67,6 +67,7 @@ TESTS = \
 	../loader/Latin1 \
 	../loader/Latin1-implicit \
 	../loader/mfile \
+	../dumper/mfiledmp \
 	../dumper/literalsrid \
 	../dumper/realtable \
 	../dumper/nullsintable \
diff --git a/regress/dumper/mfiledmp.dmp b/regress/dumper/mfiledmp.dmp
new file mode 100644
index 0000000..daccd35
--- /dev/null
+++ b/regress/dumper/mfiledmp.dmp
@@ -0,0 +1,2 @@
+SELECT * FROM (VALUES ('This is Test 1', 'TT1', 'red', ST_Point(0, 0)), ('This is Test 2', 'TT2', 'green', ST_Point(0, 100))) AS m (address, some_very_long_name, color, geom)
+-m{regdir}/dumper/mfiledmp_mapping.txt
\ No newline at end of file
diff --git a/regress/dumper/mfiledmp_expected.dbf b/regress/dumper/mfiledmp_expected.dbf
index 0000000..6a020c0
Binary files /dev/null and b/regress/dumper/mfiledmp_expected.dbf differ
diff --git a/regress/dumper/mfiledmp_expected.shp b/regress/dumper/mfiledmp_expected.shp
index 0000000..8290555
Binary files /dev/null and b/regress/dumper/mfiledmp_expected.shp differ
diff --git a/regress/dumper/mfiledmp_expected.shx b/regress/dumper/mfiledmp_expected.shx
index 0000000..314770b
Binary files /dev/null and b/regress/dumper/mfiledmp_expected.shx differ
diff --git a/regress/dumper/mfiledmp_mapping.txt b/regress/dumper/mfiledmp_mapping.txt
index 0000000..f1b20f4
--- /dev/null
+++ b/regress/dumper/mfiledmp_mapping.txt
@@ -0,0 +1,2 @@
+address add
+some_very_long_name short
commit b3ae6aadc804a98dc53727b5554bffd778e402b8
Date:   Sat Jun 20 15:12:04 2020 +0200
    Allow {regdir} keyword substitution in .dmp file; remove return from for main loop on objects count mismatch
    Can't return from outside a subroutine, also terminate the program seems too drastic,
    allow following cleaning operations
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 1e0875e..ce2c718 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -541,7 +541,6 @@ foreach $TEST (@ARGV)
 	if ( $TEST_OBJ_COUNT_POST != $TEST_OBJ_COUNT_PRE )
 		fail("PostGIS object count pre-test ($TEST_OBJ_COUNT_POST) != post-test ($TEST_OBJ_COUNT_PRE)");
-		return 0;
@@ -1170,8 +1169,8 @@ sub run_loader_test
 #  Run dumper and compare output with various expectances
 #  test and run simple test with provided expected output.
-# input is ${TEST}.dmp, where last line is considered to be the
-# [table|query] argument for pgsql2shp and all the previous lines,
+# input is ${TEST}.dmp, where first line is considered to be the
+# [table|query] argument for pgsql2shp and all the next lines,
 # if any are options.
@@ -1190,8 +1189,9 @@ sub run_dumper_test
   open DUMPFILE, "$dump_file" or die "Cannot open dump file $dump_file\n";
   my @dumplines = <DUMPFILE>;
   close DUMPFILE;
-  chop(@dumplines);
+  chomp(@dumplines);
   my $dumpstring = shift @dumplines;
+  @dumplines = map { local $_ = $_; s/{regdir}/$REGDIR/; $_ } @dumplines;
   my @cmd = ("${PGSQL2SHP}", "-f", ${shpfile});
   push @cmd, @dumplines;
   push @cmd, ${DB};
Summary of changes:
 loader/pgsql2shp-core.c              |   2 +-
 regress/core/Makefile.in             |   1 +
 regress/dumper/mfiledmp.dmp          |   2 ++
 regress/dumper/mfiledmp_expected.dbf | Bin 0 -> 175 bytes
 regress/dumper/mfiledmp_expected.shp | Bin 0 -> 156 bytes
 regress/dumper/mfiledmp_expected.shx | Bin 0 -> 116 bytes
 regress/dumper/mfiledmp_mapping.txt  |   2 ++
 regress/run_test.pl                  |   8 ++++----
 8 files changed, 10 insertions(+), 5 deletions(-)
 create mode 100644 regress/dumper/mfiledmp.dmp
 create mode 100644 regress/dumper/mfiledmp_expected.dbf
 create mode 100644 regress/dumper/mfiledmp_expected.shp
 create mode 100644 regress/dumper/mfiledmp_expected.shx
 create mode 100644 regress/dumper/mfiledmp_mapping.txt
hooks/post-receive
