[postgis-tickets] [PostGIS] #4707: Revise CREATE from unpackaged to not use temp tables
trac at osgeo.org
Wed Jun 24 12:55:19 PDT 2020
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 3.0.2
Component: build/upgrade/install | Version: 3.0.x
Keywords: |
As discussed in
https://lists.osgeo.org/pipermail/postgis-users/2020-May/044226.html
People on Amazon RDS evidentally can't upgrade from 2.? to 3.0 because we
are using temp tables.
https://forums.aws.amazon.com/thread.jspa?messageID=938665
They are getting error
SELECT PostGIS_Extensions_Upgrade()
NOTICE: Packaging extension postgis_raster
ERROR: cannot create temporary table within security-restricted
operation
CONTEXT: SQL statement "CREATE EXTENSION postgis_raster FROM unpackaged"
PL/pgSQL function postgis_extensions_upgrade() line 48 at EXECUTE
I concluded this is most likely caused by our use of temp tables in our
unpackaged script.
strk was all for the idea of removing their use as they just store version
info that we should be able to stuff in a variable since our upgrade
script is in a big DO $$ $$ call.
https://lists.osgeo.org/pipermail/postgis-devel/2020-May/028548.html
So I'll work on revising and hopefully can get Amazon to try it to see if
it fixes their issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4707>
