[postgis-tickets] [PostGIS] #4708: Add berrie64 to jenkins bot chain
PostGIS trac at osgeo.org
Wed Jun 24 13:21:40 PDT 2020
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  medium     |  Milestone:  PostGIS 2.5.5
Component:  buildbots  |    Version:  2.5.x
 Keywords:             |
 Bruce Rindahl provided us an additional Rasberry Pi which is 64-bit and
 will be called berrie64.
 old berrie also had gotten upgraded I believe to 64-bit but is running
 32-bit gcc I believe.
 Anyway will setup berrie64 to do both PostGIS and geos tests.  I'll put a
 separate ticket in for geos once I get to it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4708>
