[postgis-tickets] [PostGIS] #4709: Backend crash with TopoGeo_addLinestring against an invalid topology (2)
trac at osgeo.org
Fri Jun 26 03:17:05 PDT 2020
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone:
Component: topology | Version: master
Keywords: |
In some circumstance, the TopoGeo_addLinestring function ends up finding N
edges forming a ring from one of the edges resulting from the input
linestring (this operation is performed by following edge linking
information) and later fails to find all the corresponding edge_data
records in the topology primitive table.
NOTICE: failed after trying with tolerance 6.75 : XX000 message:
Unexpected error: 6461 edges found when expecting 6462 detail : hint :
context: SQ
L statement "SELECT ARRAY(SELECT
topology.TopoGeo_addLinestring('test_topo_t4','0102000020E9640000040000003B28C645D88B1A41366677CC3F675B413B28C645B08B1A
4123A36AD93E675B413B28C645608B1A41FD1C51F33C675B413B28C645388B1A41EA5944003C675B41',6.75))"
When such occurrence happens, the cleanup code in _lwt_MakeRingShell
attempts to release the expected number of edges, rather than the obtained
number of edges, resulting in potential access to unallocated memory
(segfault)
This is a followup of #4706 and the fix needs be backported to all
relevant branches.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4709>
