[postgis-tickets] [PostGIS] #4709: Backend crash with TopoGeo_addLinestring against an invalid topology (2)
trac at osgeo.org
Fri Jun 26 03:20:40 PDT 2020
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone:
Component: topology | Version: master
Resolution: | Keywords:
Comment (by strk):
The fix seems easy, but we need to find out how it is possible to think
more edges than available when that's not the case. Theoretically we have
a referencial integrity in place so it should NOT be possible for an edge
to reference non-existing edges, but maybe such constraint is verified
only at the end of the transaction thus leaving the door open to such
occurrence. For a test we might intentionally lift the referencial
integrity constraint, corrupt the topolody, call the function.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4709#comment:2>
