[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-141-g2ce98e2
git at osgeo.org
git at osgeo.org
Fri Jun 26 09:19:09 PDT 2020
the project "PostGIS".
via 2ce98e26bc76fc0ae615774c9d2adfa0a39df008 (commit)
from 96615d90e6d5e4716310eca25647ee373a8535f8 (commit)
revisions in full, below.
commit 2ce98e26bc76fc0ae615774c9d2adfa0a39df008
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Jun 26 17:07:24 2020 +0200
Handle non-closed edge rings by human readable error
Handle both topological and geometrical corruption
Have getRingEdges raise an error if topology is corrupted
References #4709
References #3042
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 2bc954f..173cd80 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -1898,6 +1898,14 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
return -2;
const POINTARRAY *pa = shell->rings[0];
+ if ( ! ptarray_is_closed(pa) )
+ lwpoly_free(shell);
+ lwfree( signed_edge_ids );
+ lwerror("Corrupted topology: ring of edge %" LWTFMT_ELEMID
+ " is geometrically not-closed", sedge);
+ return -2;
int isccw = ptarray_isccw(pa);
LWDEBUGF(1, "Ring of edge %" LWTFMT_ELEMID " is %sclockwise",
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index abadfb3..32bedb0 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -1231,6 +1231,40 @@ cb_getRingEdges(const LWT_BE_TOPOLOGY *topo, LWT_ELEMID edge, uint64_t *numelems
val = DatumGetInt32(dat);
edges[i] = val;
POSTGIS_DEBUGF(1, "Component " UINT64_FORMAT " in ring of edge %" LWTFMT_ELEMID " is edge %d", i, edge, val);
+ /* For the last entry, check that we returned back to start
+ * point, or complain about topology being corrupted */
+ if ( i == *numelems - 1 )
+ int32 nextedge;
+ int sidecol = val > 0 ? 3 : 4;
+ const char *sidetext = val > 0 ? "left" : "right";
+ dat = SPI_getbinval(row, rowdesc, sidecol, &isnull);
+ if ( isnull )
+ lwfree(edges);
+ cberror(topo->be_data, "Edge %d" /*LWTFMT_ELEMID*/
+ " has NULL next_%s_edge",
+ val, sidetext);
+ *numelems = UINT64_MAX;
+ return NULL;
+ nextedge = DatumGetInt32(dat);
+ POSTGIS_DEBUGF(1, "Last component in ring of edge %"
+ LWTFMT_ELEMID " (%" LWTFMT_ELEMID ") has next_%s_edge %d",
+ edge, val, sidetext, nextedge);
+ if ( nextedge != edge )
+ lwfree(edges);
+ cberror(topo->be_data, "Corrupted topology: ring of edge %"
+ LWTFMT_ELEMID " is topologically non-closed",
+ edge);
+ return NULL;
SPI_freetuptable(SPI_tuptable);
Summary of changes:
liblwgeom/lwgeom_topo.c | 8 ++++++++
topology/postgis_topology.c | 34 ++++++++++++++++++++++++++++++++++
2 files changed, 42 insertions(+)
hooks/post-receive
