[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-142-gf9db63e
Fri Jun 26 09:23:11 PDT 2020
the project "PostGIS".
       via  f9db63e9dc082534798861cdfed5c1429c36406f (commit)
      from  2ce98e26bc76fc0ae615774c9d2adfa0a39df008 (commit)
revisions in full, below.
commit f9db63e9dc082534798861cdfed5c1429c36406f
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jun 26 18:22:15 2020 +0200
    Add test for handling of edge-linking topology corruption
    References #4709
diff --git a/topology/test/regress/st_addedgemodface.sql b/topology/test/regress/st_addedgemodface.sql
index 3791480..b94beb8 100644
--- a/topology/test/regress/st_addedgemodface.sql
+++ b/topology/test/regress/st_addedgemodface.sql
@@ -520,6 +520,24 @@ SELECT f.id, r.element_type||':'||r.element_id as comp
 SELECT 'F'||face_id, st_astext(mbr) FROM city_data.face ORDER BY face_id;
+-- Check robustness in presence of corrupted topology
+-- See https://trac.osgeo.org/postgis/ticket/4709
+BEGIN; -- need a transaction to corrupt the topology
+-- 1. Corrupt topology by setting edge 5 next_face_right = 999999 (instead of 5)
+UPDATE city_data.edge_data
+  SET
+    next_left_edge = 999999,
+    abs_next_left_edge = 999999
+  WHERE edge_id = 5; -- corrupt topology
+-- 2. Try to add an edge closing a ring involving edge 5
+-- 5 | POINT(36 38)
+-- 7 | POINT(41 40)
+SELECT ST_AddEdgeModFace('city_data', 5, 7, 'LINESTRING(36 38,41 40)');
+ROLLBACK; -- restores the topology
 -- Cleanups
diff --git a/topology/test/regress/st_addedgemodface_expected b/topology/test/regress/st_addedgemodface_expected
index cfc96e0..55ccf03 100644
--- a/topology/test/regress/st_addedgemodface_expected
+++ b/topology/test/regress/st_addedgemodface_expected
@@ -206,4 +206,5 @@ F32|POLYGON((36 33,36 38,57 38,57 33,36 33))
 F33|POLYGON((38 40,38 43,41 43,41 40,38 40))
 F34|POLYGON((35 25,35 45,63 45,63 25,35 25))
 F35|POLYGON((9 14,9 22,21 22,21 14,9 14))
+ERROR:  Backend error (no ring edges for edge 58): Corrupted topology: ring of edge 58 is topologically non-closed
 Topology 'city_data' dropped
Summary of changes:
 topology/test/regress/st_addedgemodface.sql      | 18 ++++++++++++++++++
 topology/test/regress/st_addedgemodface_expected |  1 +
 2 files changed, 19 insertions(+)
hooks/post-receive
