[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. f1f62ce593df5dd6f124f939a46bef7b380022c4
Sat Jun 27 10:19:21 PDT 2020
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
       via  f1f62ce593df5dd6f124f939a46bef7b380022c4 (commit)
      from  a71ca2778d041d2196a237a71f3d26297a77f559 (commit)
revisions in full, below.
commit f1f62ce593df5dd6f124f939a46bef7b380022c4
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Jun 27 13:19:03 2020 -0400
    Berrie setup as best I could remember
diff --git a/raspberry_pi/berrie.txt b/raspberry_pi/berrie.txt
new file mode 100644
index 0000000..38c66de
--- /dev/null
+++ b/raspberry_pi/berrie.txt
@@ -0,0 +1,18 @@
+apt install default-jdk
+apt install autoconf libtool build-essential
+apt install libreadline6 libreadline6-dev zlib1g-dev
+apt install libcunit1-dev libcunit1-doc libcunit1
+apt install docbook
+apt install libxml2-dev n xsltproc docbook-xsl docbook-mathml gettext
+apt install libjson-c-dev
+apt install dblatex
+apt install imagemagick
+apt install libxml2 libxml2-dev
+apt install bison
+apt install libiconv-hook1
+apt install subversion
+apt install proj
+apt install postgresql-server-dev-9.6
+apt install libgeos-3.5 libgeos-dev libproj-dev
+apt install libgdal-dev
+apt install pkg-config
\ No newline at end of file
diff --git a/raspberry_pi/berrie64.txt b/raspberry_pi/berrie64.txt
index 0000000..a1e480f
--- /dev/null
+++ b/raspberry_pi/berrie64.txt
@@ -0,0 +1,23 @@
+berrie64 is running 64-bit Arm Raspberry Pie
+sudo bash
+apt install libxml2-dev xsltproc docbook-xsl docbook-mathml gettext
+#apt install dblatex #for pdf building
+#apt install imagemagick #for doc building
+apt install bison flex
+apt install git
+apt install proj-bin
+apt install libgeos libgeos-dev libproj-dev
+#for code coverage testing
+sudo apt install lcov
Summary of changes:
 raspberry_pi/berrie.txt   | 18 ++++++++++++++++++
 raspberry_pi/berrie64.txt | 23 +++++++++++++++++++++++
 2 files changed, 41 insertions(+)
 create mode 100644 raspberry_pi/berrie.txt
 create mode 100644 raspberry_pi/berrie64.txt
hooks/post-receive
