[postgis-tickets] [SCM] PostGIS branch stable-2.4 updated. 40b18b9fdec5fa86a5c78884b33a2d653bbe2e34
Sat Jun 27 10:28:31 PDT 2020
the project "PostGIS".
The branch, stable-2.4 has been updated
       via  40b18b9fdec5fa86a5c78884b33a2d653bbe2e34 (commit)
      from  1f3bb0e07ea453afdcac272540598e0a32088ed2 (commit)
revisions in full, below.
commit 40b18b9fdec5fa86a5c78884b33a2d653bbe2e34
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Jun 27 13:28:24 2020 -0400
    cloud.drone.io to use different script from dronie.osgeo.org closes #4704 for PostGIS 2.4
diff --git a/.cloud-drone.yml b/.cloud-drone.yml
new file mode 100644
index 0000000..fcccf9a
--- /dev/null
+++ b/.cloud-drone.yml
@@ -0,0 +1,51 @@
+# This is for the drone 1.0 agent
+# https://docs.drone.io/user-guide/pipeline/steps/
+# https://cloud.drone.io/postgis #1.0 server
+# See https://git.osgeo.org/gitea/postgis/postgis-docker
+# todo: add docker images from https://hub.docker.com/r/postgis/postgis-build-env/tags/
+test-image: &test-image docker.osgeo.org/postgis/build-test:trisquel2
+kind: pipeline
+name: pg-9.4
+steps:
+  - name: build
+    image: *test-image
+    pull: true
+    commands:
+      - export PGVER=9.4
+      - service postgresql start $PGVER
+      - export PGPORT=`grep ^port /etc/postgresql/$PGVER/main/postgresql.conf | awk '{print $3}'`
+      - export PATH=/usr/lib/postgresql/$PGVER/bin:$PATH
+      - psql --version
+      - ./autogen.sh
+      - ./configure CFLAGS="-O0 -Wall -fno-omit-frame-pointer" --without-interrupt-tests
+      - make -j
+      # we should maybe wait for postgresql service to startup here...
+      - psql -c "select version()" template1
+      - make check RUNTESTFLAGS=-v
+      - make install
+      - utils/check_all_upgrades.sh -s
+        `grep '^POSTGIS_' Version.config | cut -d= -f2 | paste -sd '.'`
+kind: pipeline
+name: pg-9.5
+steps:
+  - name: build
+    pull: true
+    commands:
+      - export PGVER=9.5
+      - psql --version
+      - ./autogen.sh
+      - make -j
+      - make install
Summary of changes:
 .cloud-drone.yml | 51 +++++++++++++++++++++++++++++++++++++++++++++++++++
 1 file changed, 51 insertions(+)
 create mode 100644 .cloud-drone.yml
hooks/post-receive
