[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.1-24-gaeea512
Mon Jun 29 02:28:27 PDT 2020
the project "PostGIS".
The branch, stable-3.0 has been updated
       via  aeea5121b2a99137e67ea4177c8b5d43efcba35d (commit)
       via  273b7eaad3e9a6dfae8eef9e29f78dd67582a4ca (commit)
       via  037eba580cc6de9b4a2bc5c4777bb081bad401f1 (commit)
      from  c76d1b1178065e5f540b848bb37cfa43dcb61982 (commit)
revisions in full, below.
commit aeea5121b2a99137e67ea4177c8b5d43efcba35d
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jun 29 11:17:41 2020 +0200
    Update NEWS file
diff --git a/NEWS b/NEWS
index f97f0bf..1964cbe 100644
--- a/NEWS
+++ b/NEWS
@@ -2,6 +2,8 @@ PostGIS 3.0.2
 2020/XX/XX
 * Bug Fixes and Enhancements *
+  - #4709, Fix crash in adding edge to corrupted topology, (Sandro Santilli)
+  - Handle non-closed edge rings by human readable error (Sandro Santilli)
   - #4706, Fix crash in ST_ChangeEdgeGeom on corrupted topology (Sandro Santilli)
   - #4652, Fix several memory related bugs in ST_GeomFromGML (Raúl Marín)
   - #4661, Fix access to spatial_ref_sys with a non default schema (Raúl Marín)
commit 273b7eaad3e9a6dfae8eef9e29f78dd67582a4ca
Date:   Fri Jun 26 17:07:24 2020 +0200
    Handle both topological and geometrical corruption
    Have getRingEdges raise an error if topology is corrupted
    Includes test.
    References #4709 in 3.0 branch
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index f140d8f..652f7da 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -1898,6 +1898,14 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
     return -2;
   const POINTARRAY *pa = shell->rings[0];
+  if ( ! ptarray_is_closed(pa) )
+    lwpoly_free(shell);
+    lwfree( signed_edge_ids );
+    lwerror("Corrupted topology: ring of edge %" LWTFMT_ELEMID
+            " is geometrically not-closed", sedge);
+    return -2;
   int isccw = ptarray_isccw(pa);
   LWDEBUGF(1, "Ring of edge %" LWTFMT_ELEMID " is %sclockwise",
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index a5d3b0c..2a7e851 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -1241,6 +1241,40 @@ cb_getRingEdges(const LWT_BE_TOPOLOGY *topo, LWT_ELEMID edge, uint64_t *numelems
     val = DatumGetInt32(dat);
     edges[i] = val;
     POSTGIS_DEBUGF(1, "Component " UINT64_FORMAT " in ring of edge %" LWTFMT_ELEMID " is edge %d", i, edge, val);
+    /* For the last entry, check that we returned back to start
+     * point, or complain about topology being corrupted */
+    if ( i == *numelems - 1 )
+      int32 nextedge;
+      int sidecol = val > 0 ? 3 : 4;
+      const char *sidetext = val > 0 ? "left" : "right";
+      dat = SPI_getbinval(row, rowdesc, sidecol, &isnull);
+      if ( isnull )
+        lwfree(edges);
+        cberror(topo->be_data, "Edge %d" /*LWTFMT_ELEMID*/
+                               " has NULL next_%s_edge",
+                               val, sidetext);
+        *numelems = UINT64_MAX;
+        return NULL;
+      nextedge = DatumGetInt32(dat);
+      POSTGIS_DEBUGF(1, "Last component in ring of edge %"
+                        LWTFMT_ELEMID " (%" LWTFMT_ELEMID ") has next_%s_edge %d",
+                        edge, val, sidetext, nextedge);
+      if ( nextedge != edge )
+        lwfree(edges);
+        cberror(topo->be_data, "Corrupted topology: ring of edge %"
+                               LWTFMT_ELEMID " is topologically non-closed",
+                               edge);
+        return NULL;
   SPI_freetuptable(SPI_tuptable);
diff --git a/topology/test/regress/st_addedgemodface.sql b/topology/test/regress/st_addedgemodface.sql
index 3791480..2939c22 100644
--- a/topology/test/regress/st_addedgemodface.sql
+++ b/topology/test/regress/st_addedgemodface.sql
@@ -520,6 +520,22 @@ SELECT f.id, r.element_type||':'||r.element_id as comp
 SELECT 'F'||face_id, st_astext(mbr) FROM city_data.face ORDER BY face_id;
+-- Check robustness in presence of corrupted topology
+-- See https://trac.osgeo.org/postgis/ticket/4709
+BEGIN; -- need a transaction to corrupt the topology
+-- 1. Corrupt topology by setting edge 5 next_left_edge = 999999 (instead of -4)
+UPDATE city_data.edge_data
+  SET
+    next_left_edge = 999999,
+    abs_next_left_edge = 999999
+  WHERE edge_id = 5; -- corrupt topology
+-- 2. Try to add an edge closing a ring involving edge 5
+SELECT ST_AddEdgeModFace('city_data', 5, 7, 'LINESTRING(36 38,41 40)');
+ROLLBACK; -- restores the topology
 -- Cleanups
diff --git a/topology/test/regress/st_addedgemodface_expected b/topology/test/regress/st_addedgemodface_expected
index cfc96e0..55ccf03 100644
--- a/topology/test/regress/st_addedgemodface_expected
+++ b/topology/test/regress/st_addedgemodface_expected
@@ -206,4 +206,5 @@ F32|POLYGON((36 33,36 38,57 38,57 33,36 33))
 F33|POLYGON((38 40,38 43,41 43,41 40,38 40))
 F34|POLYGON((35 25,35 45,63 45,63 25,35 25))
 F35|POLYGON((9 14,9 22,21 22,21 14,9 14))
+ERROR:  Backend error (no ring edges for edge 58): Corrupted topology: ring of edge 58 is topologically non-closed
 Topology 'city_data' dropped
commit 037eba580cc6de9b4a2bc5c4777bb081bad401f1
Date:   Fri Jun 26 12:01:47 2020 +0200
    Fix release of unexpected number of edges from a returned edge ring
index 0926888..f140d8f 100644
@@ -1771,7 +1771,7 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
   else if ( i != numedges )
-    _lwt_release_edges(ring_edges, numedges);
+    _lwt_release_edges(ring_edges, i);
     lwerror("Unexpected error: %d edges found when expecting %d", i, numedges);
     return NULL;
Summary of changes:
 NEWS                                             |  2 ++
 liblwgeom/lwgeom_topo.c                          | 10 ++++++-
 topology/postgis_topology.c                      | 34 ++++++++++++++++++++++++
 topology/test/regress/st_addedgemodface.sql      | 16 +++++++++++
 topology/test/regress/st_addedgemodface_expected |  1 +
 5 files changed, 62 insertions(+), 1 deletion(-)
hooks/post-receive
