[postgis-tickets] [SCM] PostGIS branch stable-2.5 updated. 2.5.4-20-g65e73de
git at osgeo.org
git at osgeo.org
Mon Jun 29 02:35:44 PDT 2020
the project "PostGIS".
The branch, stable-2.5 has been updated
via 65e73de493df9d0bcc1ddb8762756ab2e8b069ed (commit)
via 456ee529a787dfa44b53f0e2fb6a7e18d693cc20 (commit)
via 8258c1668350282a678e914b447f85568590d2f9 (commit)
from 778d66b336f613e1072ff53b2e206a51d344d706 (commit)
revisions in full, below.
commit 65e73de493df9d0bcc1ddb8762756ab2e8b069ed
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jun 29 11:24:56 2020 +0200
Update NEWS file
diff --git a/NEWS b/NEWS
index 291bb5f..5e5c212 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,8 @@ PostGIS 2.5.5
* Bug fixes *
+ - #4709, Fix crash in adding edge to corrupted topology, (Sandro Santilli)
+ - Handle non-closed edge rings by human readable error (Sandro Santilli)
- #4706, Fix crash in ST_ChangeEdgeGeom on corrupted topology (Sandro Santilli)
- #4652, Fix several memory related bugs in ST_GeomFromGML (Raúl Marín)
- #4661, Fix access to spatial_ref_sys with a non default schema (Raúl Marín)
commit 456ee529a787dfa44b53f0e2fb6a7e18d693cc20
Date: Fri Jun 26 17:07:24 2020 +0200
Handle both topological and geometrical corruption
Have getRingEdges raise an error if topology is corrupted
Includes test.
References #4709 in 2.5 branch
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 8b0bca8..308f64e 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -1899,6 +1899,14 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
return -2;
const POINTARRAY *pa = shell->rings[0];
+ if ( ! ptarray_is_closed(pa) )
+ lwpoly_free(shell);
+ lwfree( signed_edge_ids );
+ lwerror("Corrupted topology: ring of edge %" LWTFMT_ELEMID
+ " is geometrically not-closed", sedge);
+ return -2;
int isccw = ptarray_isccw(pa);
LWDEBUGF(1, "Ring of edge %" LWTFMT_ELEMID " is %sclockwise",
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index adb0c51..abb70e5 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -1248,8 +1248,41 @@ cb_getRingEdges(const LWT_BE_TOPOLOGY* topo,
val = DatumGetInt32(dat);
edges[i] = val;
- POSTGIS_DEBUGF(1, "Component %d in ring of edge %" LWTFMT_ELEMID
- " is edge %d", i, edge, val);
+ POSTGIS_DEBUGF(1, "Component " UINT64_FORMAT " in ring of edge %" LWTFMT_ELEMID " is edge %d", i, edge, val);
+ /* For the last entry, check that we returned back to start
+ * point, or complain about topology being corrupted */
+ if ( i == *numelems - 1 )
+ int32 nextedge;
+ int sidecol = val > 0 ? 3 : 4;
+ const char *sidetext = val > 0 ? "left" : "right";
+ dat = SPI_getbinval(row, rowdesc, sidecol, &isnull);
+ if ( isnull )
+ lwfree(edges);
+ cberror(topo->be_data, "Edge %d" /*LWTFMT_ELEMID*/
+ " has NULL next_%s_edge",
+ val, sidetext);
+ *numelems = UINT64_MAX;
+ return NULL;
+ nextedge = DatumGetInt32(dat);
+ POSTGIS_DEBUGF(1, "Last component in ring of edge %"
+ LWTFMT_ELEMID " (%" LWTFMT_ELEMID ") has next_%s_edge %d",
+ edge, val, sidetext, nextedge);
+ if ( nextedge != edge )
+ lwfree(edges);
+ cberror(topo->be_data, "Corrupted topology: ring of edge %"
+ LWTFMT_ELEMID " is topologically non-closed",
+ edge);
+ return NULL;
SPI_freetuptable(SPI_tuptable);
diff --git a/topology/test/regress/st_addedgemodface.sql b/topology/test/regress/st_addedgemodface.sql
index 3791480..2939c22 100644
--- a/topology/test/regress/st_addedgemodface.sql
+++ b/topology/test/regress/st_addedgemodface.sql
@@ -520,6 +520,22 @@ SELECT f.id, r.element_type||':'||r.element_id as comp
SELECT 'F'||face_id, st_astext(mbr) FROM city_data.face ORDER BY face_id;
+-- Check robustness in presence of corrupted topology
+-- See https://trac.osgeo.org/postgis/ticket/4709
+BEGIN; -- need a transaction to corrupt the topology
+-- 1. Corrupt topology by setting edge 5 next_left_edge = 999999 (instead of -4)
+UPDATE city_data.edge_data
+ SET
+ next_left_edge = 999999,
+ abs_next_left_edge = 999999
+ WHERE edge_id = 5; -- corrupt topology
+-- 2. Try to add an edge closing a ring involving edge 5
+SELECT ST_AddEdgeModFace('city_data', 5, 7, 'LINESTRING(36 38,41 40)');
+ROLLBACK; -- restores the topology
-- Cleanups
diff --git a/topology/test/regress/st_addedgemodface_expected b/topology/test/regress/st_addedgemodface_expected
index cb03d42..92d99e6 100644
--- a/topology/test/regress/st_addedgemodface_expected
+++ b/topology/test/regress/st_addedgemodface_expected
@@ -208,4 +208,7 @@ F32|POLYGON((36 33,36 38,57 38,57 33,36 33))
F33|POLYGON((38 40,38 43,41 43,41 40,38 40))
F34|POLYGON((35 25,35 45,63 45,63 25,35 25))
F35|POLYGON((9 14,9 22,21 22,21 14,9 14))
+BEGIN
+ERROR: Backend error (no ring edges for edge 58): Corrupted topology: ring of edge 58 is topologically non-closed
+COMMIT
Topology 'city_data' dropped
commit 8258c1668350282a678e914b447f85568590d2f9
Date: Fri Jun 26 12:01:47 2020 +0200
Fix release of unexpected number of edges from a returned edge ring
index 073bb03..8b0bca8 100644
@@ -1773,7 +1773,7 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, int num_sign
else if ( i != numedges )
- _lwt_release_edges(ring_edges, numedges);
+ _lwt_release_edges(ring_edges, i);
lwerror("Unexpected error: %d edges found when expecting %d", i, numedges);
return NULL;
Summary of changes:
NEWS | 2 ++
liblwgeom/lwgeom_topo.c | 10 ++++++-
topology/postgis_topology.c | 37 ++++++++++++++++++++++--
topology/test/regress/st_addedgemodface.sql | 16 ++++++++++
topology/test/regress/st_addedgemodface_expected | 3 ++
5 files changed, 65 insertions(+), 3 deletions(-)
hooks/post-receive
