[postgis-tickets] [SCM] PostGIS branch stable-2.4 updated. d35888bc6e787c37f3e393405ffc1792f1c5fce2
git at osgeo.org
git at osgeo.org
Mon Jun 29 02:55:38 PDT 2020
the project "PostGIS".
The branch, stable-2.4 has been updated
via d35888bc6e787c37f3e393405ffc1792f1c5fce2 (commit)
via 03e71313c564f735b3b0cf98849f02dff6f048e5 (commit)
via 40c8a06d838ace80a9fd0f69dd835063bb437261 (commit)
from 40b18b9fdec5fa86a5c78884b33a2d653bbe2e34 (commit)
revisions in full, below.
commit d35888bc6e787c37f3e393405ffc1792f1c5fce2
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Jun 29 11:53:31 2020 +0200
Add NEWS section
diff --git a/NEWS b/NEWS
index 2590837..4f36151 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,8 @@ PostGIS 2.4.9
* Bug Fixes and Enhancements *
+ - #4709, Fix crash in adding edge to corrupted topology, (Sandro Santilli)
+ - Handle non-closed edge rings by human readable error (Sandro Santilli)
- #4706, Fix crash in ST_ChangeEdgeGeom on corrupted topology (Sandro Santilli)
- #4480, Geography Distance inconsistent with Intersects (Paul Ramsey)
- #4481, Improve libprotobuf detection for old systems (Paul Ramsey)
commit 03e71313c564f735b3b0cf98849f02dff6f048e5
Date: Mon Jun 29 11:14:07 2020 +0200
Handle both topological and geometrical corruption
Have getRingEdges raise an error if topology is corrupted
Includes test.
References #4709 in 2.4 branch
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 5718b88..3e1a2f0 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -1115,6 +1115,41 @@ cb_getRingEdges(const LWT_BE_TOPOLOGY* topo,
edges[i] = val;
POSTGIS_DEBUGF(1, "Component %d in ring of edge %" LWTFMT_ELEMID
" is edge %d", i, edge, val);
+ /* For the last entry, check that we returned back to start
+ * point, or complain about topology being corrupted */
+ if ( i == *numelems - 1 )
+ int32 nextedge;
+ int sidecol = val > 0 ? 3 : 4;
+ const char *sidetext = val > 0 ? "left" : "right";
+ dat = SPI_getbinval(row, rowdesc, sidecol, &isnull);
+ if ( isnull )
+ lwfree(edges);
+ cberror(topo->be_data, "Edge %d" /*LWTFMT_ELEMID*/
+ " has NULL next_%s_edge",
+ val, sidetext);
+ *numelems = UINT64_MAX;
+ return NULL;
+ nextedge = DatumGetInt32(dat);
+ POSTGIS_DEBUGF(1, "Last component in ring of edge %"
+ LWTFMT_ELEMID " (%" LWTFMT_ELEMID ") has next_%s_edge %d",
+ edge, val, sidetext, nextedge);
+ if ( nextedge != edge )
+ lwfree(edges);
+ cberror(topo->be_data, "Corrupted topology: ring of edge %"
+ LWTFMT_ELEMID " is topologically non-closed",
+ edge);
+ return NULL;
SPI_freetuptable(SPI_tuptable);
diff --git a/topology/test/regress/st_addedgemodface.sql b/topology/test/regress/st_addedgemodface.sql
index 25881cf..f6a5c81 100644
--- a/topology/test/regress/st_addedgemodface.sql
+++ b/topology/test/regress/st_addedgemodface.sql
@@ -521,6 +521,23 @@ SELECT f.id, r.element_type||':'||r.element_id as comp
SELECT 'F'||face_id, st_astext(mbr) FROM city_data.face ORDER BY face_id;
+-- Check robustness in presence of corrupted topology
+-- See https://trac.osgeo.org/postgis/ticket/4709
+BEGIN; -- need a transaction to corrupt the topology
+-- 1. Corrupt topology by setting edge 5 next_face_right = 999999 (instead of 5)
+UPDATE city_data.edge_data
+ SET
+ next_left_edge = 999999,
+ abs_next_left_edge = 999999
+ WHERE edge_id = 5; -- corrupt topology
+-- 2. Try to add an edge closing a ring involving edge 5
+-- 5 | POINT(36 38)
+-- 7 | POINT(41 40)
+SELECT ST_AddEdgeModFace('city_data', 5, 7, 'LINESTRING(36 38,41 40)');
+ROLLBACK; -- restores the topology
-- Cleanups
diff --git a/topology/test/regress/st_addedgemodface_expected b/topology/test/regress/st_addedgemodface_expected
index cb03d42..92d99e6 100644
--- a/topology/test/regress/st_addedgemodface_expected
+++ b/topology/test/regress/st_addedgemodface_expected
@@ -208,4 +208,7 @@ F32|POLYGON((36 33,36 38,57 38,57 33,36 33))
F33|POLYGON((38 40,38 43,41 43,41 40,38 40))
F34|POLYGON((35 25,35 45,63 45,63 25,35 25))
F35|POLYGON((9 14,9 22,21 22,21 14,9 14))
+BEGIN
+ERROR: Backend error (no ring edges for edge 58): Corrupted topology: ring of edge 58 is topologically non-closed
+COMMIT
Topology 'city_data' dropped
commit 40c8a06d838ace80a9fd0f69dd835063bb437261
Date: Mon Jun 29 11:11:37 2020 +0200
Fix release of unexpected number of edges from a returned edge ring
Closes #4709 in 2.4 branch
diff --git a/liblwgeom/lwgeom_topo.c b/liblwgeom/lwgeom_topo.c
index 6aa8936..c55f949 100644
--- a/liblwgeom/lwgeom_topo.c
+++ b/liblwgeom/lwgeom_topo.c
@@ -1839,7 +1839,7 @@ _lwt_AddFaceSplit( LWT_TOPOLOGY* topo,
else if ( i != numedges )
lwfree( signed_edge_ids );
- _lwt_release_edges(ring_edges, numedges);
+ _lwt_release_edges(ring_edges, i);
lwerror("Unexpected error: %d edges found when expecting %d", i, numedges);
return -2;
Summary of changes:
NEWS | 2 ++
liblwgeom/lwgeom_topo.c | 2 +-
topology/postgis_topology.c | 35 ++++++++++++++++++++++++
topology/test/regress/st_addedgemodface.sql | 17 ++++++++++++
topology/test/regress/st_addedgemodface_expected | 3 ++
5 files changed, 58 insertions(+), 1 deletion(-)
hooks/post-receive
