[postgis-tickets] [PostGIS] #4685: Error upgrading postGIS from 2.4.4 to 2.5.4 on postgres 10.12
PostGIS trac at osgeo.org
Mon Jun 29 06:49:13 PDT 2020
  Reporter:  sjezewskisf            |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 2.5.5
 Component:  build/upgrade/install  |    Version:  2.5.x
Resolution:                         |   Keywords:
Changes (by robe):
 * priority:  medium => blocker
 * owner:  pramsey => strk
 * component:  postgis => build/upgrade/install
Comment:
 This should be called the bug that keeps on giving.
 Looks like we have a couple of tickets of this all closed #3683 which you
 mentioned and #3633 and #4257
 By chance are the databases you are having trouble with been pg_upgraded
 from a Pre-PostgreSQL 9.4 edition? It seems a bit odd you'd be running
 into this otherwise.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4685#comment:3>
