[postgis-tickets] [SCM] PostGIS branch stable-2.4 updated. a4fc2ab56533518605a4e821093372b529a1ffb4
Tue Jun 30 18:47:16 PDT 2020
the project "PostGIS".
The branch, stable-2.4 has been updated
       via  a4fc2ab56533518605a4e821093372b529a1ffb4 (commit)
      from  cf5434a94881f10a048d8757806e33437b744a9f (commit)
revisions in full, below.
commit a4fc2ab56533518605a4e821093372b529a1ffb4
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Jun 30 21:47:10 2020 -0400
    Try to make the bessies happy with sfcgal test- try 2
diff --git a/regress/regress_ogc.sql b/regress/regress_ogc.sql
index d002213..84d44bb 100644
--- a/regress/regress_ogc.sql
+++ b/regress/regress_ogc.sql
@@ -157,7 +157,7 @@ SELECT 'overlaps', ST_overlaps('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'::geometr
 SELECT 'isvalid', ST_isvalid('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'::geometry);
 SELECT 'isvalid', ST_isvalid('POLYGON((0 0, 0 10, 10 10, -5 10, 10 0, 0 0))'::geometry);
 SELECT 'isvalid', ST_isvalid('GEOMETRYCOLLECTION EMPTY'::geometry);
-SELECT 'intersection', ST_astext(ST_intersection('LINESTRING(0 10, 0 0)'::geometry, 'LINESTRING(0 0, 1 1)'::geometry));
+SELECT 'intersection', ST_astext(ST_intersection('LINESTRING(0 10, 0 0, 1 2)'::geometry, 'LINESTRING(0 0, 1 1)'::geometry));
 SELECT 'difference', ST_astext(ST_difference('LINESTRING(0 10, 0 -10)'::GEOMETRY, 'LINESTRING(0 2, 0 -2)'::GEOMETRY));
 SELECT 'boundary', ST_astext(ST_boundary('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(2 2, 2 4, 4 4, 4 2, 2 2))'::geometry));
 SELECT 'symdifference', ST_astext(ST_symdifference('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(2 2, 2 4, 4 4, 4 2, 2 2))'::geometry, 'LINESTRING(0 0, 20 20)'::geometry));
Summary of changes:
 regress/regress_ogc.sql | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
