[postgis-tickets] [PostGIS] #4650: Can't install postgis_sfcgal
trac at osgeo.org
Sun Mar 1 17:18:13 PST 2020
Reporter: robe | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.1.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Comment (by robe):
CREATE EXTENSION postgis_sfcgal seems to run okay on my local pc pg12 run
so not sure where this is failing on debbie.
I'll look at tomorrow. I thought bessies were failing too but I think
that was the 2.3 run which is not supported on PG 11.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4650#comment:1>
