[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-24-gff6855b
Mon Mar 2 14:23:25 PST 2020
the project "PostGIS".
       via  ff6855bb4f8894db2e713a6f4ca0ff5213aa3db4 (commit)
      from  a4e8d02e24e7fef16b54b334addabc25bb3a2cf9 (commit)
revisions in full, below.
commit ff6855bb4f8894db2e713a6f4ca0ff5213aa3db4
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Mon Mar 2 14:23:17 2020 -0800
    re-enable aggregate/view upgrade test, for better or worse, closes #4386
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 16a1290..c3412e3 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -312,14 +312,15 @@ sub create_upgrade_test_objects
     exit(1);
-  # my $query = "create view upgrade_view_test as ";
-  # $query .= "select st_union(g1) from upgrade_test;";
-  # my $ret = sql($query);
-  # unless ( $ret =~ /^CREATE/ ) {
-  #   `dropdb $DB`;
-  #   print "\nSomething went wrong creating upgrade_view_test view: $ret.\n";
-  #   exit(1);
+  my $query = "create view upgrade_view_test as ";
+  $query .= "select st_union(g1) from upgrade_test;";
+  my $ret = sql($query);
+  unless ( $ret =~ /^CREATE/ ) {
+    `dropdb $DB`;
+    print "\nSomething went wrong creating upgrade_view_test view: $ret.\n";
+    exit(1);
   if ( $OPT_WITH_RASTER )
@@ -357,12 +358,12 @@ sub drop_upgrade_test_objects
   # TODO: allow passing the "upgrade-cleanup" script via commandline
-  # my $ret = sql("drop view upgrade_view_test;");
-  # unless ( $ret =~ /^DROP/ ) {
-  #   `dropdb $DB`;
-  #   print "\nSomething went wrong dropping spatial view: $ret.\n";
-  #   exit(1);
+  my $ret = sql("drop view upgrade_view_test;");
+  unless ( $ret =~ /^DROP/ ) {
+    `dropdb $DB`;
+    print "\nSomething went wrong dropping spatial view: $ret.\n";
+    exit(1);
   my $ret = sql("drop table upgrade_test;");
diff --git a/topology/test/load_topology.sql.in b/topology/test/load_topology.sql.in
index d47d8a5..0537020 100644
--- a/topology/test/load_topology.sql.in
+++ b/topology/test/load_topology.sql.in
@@ -22,7 +22,7 @@ BEGIN;
 -- NOTE:
 --  Returns topology id... which depend on how many
 --  topologies where created in the regress database
---  so we just check it's a number greater than 0
+--  so we just check it is a number greater than 0
 SELECT topology.CreateTopology('city_data', @SRID@) > 0;
Summary of changes:
 regress/run_test.pl                | 29 +++++++++++++++--------------
 topology/test/load_topology.sql.in |  2 +-
 2 files changed, 16 insertions(+), 15 deletions(-)
hooks/post-receive
