[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-30-gaf7bb36
Wed Mar 4 07:54:39 PST 2020
the project "PostGIS".
       via  af7bb360b5d9cc02dbf04f6dd395e0706536b5a4 (commit)
      from  d1a929f3c9557156c2a4d4c1606487f4fe80b0cd (commit)
revisions in full, below.
commit af7bb360b5d9cc02dbf04f6dd395e0706536b5a4
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Mar 4 15:40:19 2020 +0100
    Use Perl for the "postgis" command
diff --git a/loader/Makefile.in b/loader/Makefile.in
index 96e05d7..9aebfe0 100644
--- a/loader/Makefile.in
+++ b/loader/Makefile.in
@@ -101,8 +101,8 @@ $(PGSQL2SHP-CLI): $(SHPLIB_OBJS) pgsql2shp-core.o pgsql2shp-cli.o $(LIBLWGEOM)
 	$(LIBTOOL) --mode=link \
 	  $(CC) $(CFLAGS) $^ $(LDFLAGS) $(ICONV_LDFLAGS) $(PGSQL_FE_LDFLAGS) $(GETTEXT_LDFLAGS) -o $@
-$(POSTGIS-CLI): postgis.sh
-	cp postgis.sh postgis; chmod +x postgis
+$(POSTGIS-CLI): postgis.pl
+	cp postgis.pl postgis; chmod +x postgis
 $(SHP2PGSQL-CLI): $(SHPLIB_OBJS) shp2pgsql-core.o shp2pgsql-cli.o $(LIBLWGEOM)
diff --git a/loader/postgis.pl b/loader/postgis.pl
new file mode 100644
index 0000000..925b7a3
--- /dev/null
+++ b/loader/postgis.pl
@@ -0,0 +1,123 @@
+#!/usr/bin/perl
+# PostGIS - Spatial Types for PostgreSQL
+# http://postgis.net
+# Copyright (C) 2020 Sandro Santilli <strk at kbt.io>
+# This is free software; you can redistribute and/or modify it under
+# the terms of the GNU General Public Licence. See the COPYING file.
+sub usage
+	print qq{Usage: $0 <command> [<args>]
+Commands:
+  help               print this message and exits
+  enable <database>  enable postgis in given database
+  upgrade <database>  enable postgis in given database
+  status <database>  prints postgis status in given database
+sub enable
+	print "Enable called with args: @_\n";
+  my $db = shift;
+  die "Please specify a database name" unless "$db";
+  die "Enable is not implemented yet";
+sub upgrade
+  die "Please specify at least a database name" unless @_;
+  foreach my $db (@_)
+    print "upgrading db $db\n";
+    my $LOG=`cat <<EOF | psql -XtA ${db}
+BEGIN;
+UPDATE pg_catalog.pg_extension SET extversion = 'ANY'
+ WHERE extname IN (
+			'postgis',
+			'postgis_raster',
+			'postgis_sfcgal',
+			'postgis_topology',
+			'postgis_tiger_geocoder'
+SELECT postgis_extensions_upgrade();
+COMMIT;
+EOF`;
+sub status
+    my $sql = "
+SELECT n.nspname
+  FROM pg_namespace n, pg_proc p
+  WHERE n.oid = p.pronamespace
+    AND p.proname = 'postgis_full_version'
+		my $SCHEMA=`psql -XtA ${db} -c "${sql}"`;
+		chop($SCHEMA);
+    if ( ! "$SCHEMA" )
+      print "db $db does not have postgis enabled\n";
+      next;
+    $sql="SELECT ${SCHEMA}.postgis_full_version()";
+    my $FULL_VERSION=`psql -XtA ${db} -c "${sql}"`;
+		#print "FULL_VERSION: ${FULL_VERSION}\n";
+    #POSTGIS="3.1.0dev r3.1.0alpha1-3-gfc5392de7"
+    my $VERSION="unknown";
+    if ( $FULL_VERSION =~ /POSTGIS="([^ ]*).*/ )
+			$VERSION=$1;
+    my $EXTENSION='';
+    if ( $FULL_VERSION =~ /\[EXTENSION\]/ )
+      $EXTENSION=" as extension";
+    my $NEED_UPGRADE='';
+    if ( $FULL_VERSION =~ /need upgrade/ )
+      $NEED_UPGRADE=" - NEEDS UPGRADE";
+    print "db $db has postgis ${VERSION}${EXTENSION} in schema ${SCHEMA}${NEED_UPGRADE}\n";
+my $cmd = shift;
+if ( $cmd eq "help" ) {
+	usage(STDOUT);
+	exit 0;
+elsif ( $cmd eq "enable" ) {
+	exit enable(@ARGV);
+elsif ( $cmd eq "upgrade" ) {
+	exit upgrade(@ARGV);
+elsif ( $cmd eq "status" ) {
+	exit status(@ARGV);
+else {
+	print STDERR "Unrecognized command: $cmd\n";
+  usage(STDERR);
+  exit 1
diff --git a/loader/postgis.sh b/loader/postgis.sh
deleted file mode 100644
index 9378715..0000000
--- a/loader/postgis.sh
+++ /dev/null
@@ -1,110 +0,0 @@
-#!/bin/sh
-usage() {
-  echo "Usage: $0 <command> [<args>]"
-  echo "Commands:"
-  echo "  help               print this message and exits"
-  echo "  enable <database>  enable postgis in given database"
-  echo "  upgrade <database>  enable postgis in given database"
-  echo "  status <database>  prints postgis status in given database"
-enable() {
-  db="$1"; shift
-  test -n "$db" || {
-    echo "Please specify a database name" >&2
-    return 1
-  echo "Enable is not implemented yet" >&2
-  return 1
-upgrade() {
-  test -n "$1" || {
-    echo "Please specify at least a database name" >&2
-    return 1
-  for db in $@; do
-    echo "upgrading db $db"
-    LOG=`cat <<EOF | psql -XtA ${db}
-BEGIN;
-UPDATE pg_catalog.pg_extension SET extversion = 'ANY'
- WHERE extname IN (
-			'postgis',
-			'postgis_raster',
-			'postgis_sfcgal',
-			'postgis_topology',
-			'postgis_tiger_geocoder'
-SELECT postgis_extensions_upgrade();
-COMMIT;
-EOF`
-    #sh $0 status ${db}
-  done
-status() {
-  test -n "$1" || {
-    return 1
-  for db in $@; do
-    SCHEMA=`cat <<EOF | psql -XtA ${db}
-SELECT n.nspname
-  FROM pg_namespace n, pg_proc p
-  WHERE n.oid = p.pronamespace
-    AND p.proname = 'postgis_full_version'
-EOF
-    if test -z "$SCHEMA"; then
-      echo "db $db does not have postgis enabled"
-      continue
-    fi
-    FULL_VERSION=`cat <<EOF | psql -XtA ${db}
-SELECT ${SCHEMA}.postgis_full_version()
-EOF
-    #POSTGIS="3.1.0dev r3.1.0alpha1-3-gfc5392de7"
-    VERSION=`echo "$FULL_VERSION" | sed 's/POSTGIS="\([^ ]*\).*/\1/'`
-    EXTENSION=
-    if expr "$FULL_VERSION" : '.*\[EXTENSION\]' > /dev/null; then
-      EXTENSION=" as extension"
-    fi
-    NEED_UPGRADE=
-    if expr "$FULL_VERSION" : '.*need upgrade' > /dev/null; then
-      NEED_UPGRADE=" - NEEDS UPGRADE"
-    fi
-    echo "db $db has postgis ${VERSION}${EXTENSION} in schema ${SCHEMA}${NEED_UPGRADE}"
-  done
-test -n "$1" || {
-  usage >&2
-  exit 1
-while test -n "$1"; do
-  if test "$1" = "help"; then
-    usage 0
-  elif test "$1" = "enable"; then
-    shift
-    enable $@
-    exit $?
-  elif test "$1" = "upgrade"; then
-    shift
-    upgrade $@
-    exit $?
-  elif test "$1" = "status"; then
-    shift
-    status $@
-    exit $?
-  else
-    echo "Unrecognized command: $1" >&2
-    usage >&2
-    exit 1
-  fi
-  shift
-done
Summary of changes:
 loader/Makefile.in |   4 +-
 loader/postgis.pl  | 123 +++++++++++++++++++++++++++++++++++++++++++++++++++++
 loader/postgis.sh  | 110 -----------------------------------------------
 3 files changed, 125 insertions(+), 112 deletions(-)
 create mode 100644 loader/postgis.pl
 delete mode 100644 loader/postgis.sh
hooks/post-receive
