[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha1-32-g2f7b95e
git at osgeo.org
git at osgeo.org
Wed Mar 4 15:21:23 PST 2020
the project "PostGIS".
via 2f7b95e6b7e783c1ed9260c217c0d237ea3bd9a6 (commit)
via 5304a6f69714caa1822e51a7c3e3e4967174b690 (commit)
from af7bb360b5d9cc02dbf04f6dd395e0706536b5a4 (commit)
revisions in full, below.
commit 2f7b95e6b7e783c1ed9260c217c0d237ea3bd9a6
Merge: af7bb36 5304a6f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Mar 4 15:20:47 2020 -0800
Merge branch 'master-4614'
commit 5304a6f69714caa1822e51a7c3e3e4967174b690
Date: Wed Mar 4 11:15:24 2020 -0800
Optimize stringbuffer_append to avoid strlen calls, References #4614
diff --git a/liblwgeom/lwout_kml.c b/liblwgeom/lwout_kml.c
index 231c8b4..eb3ebe3 100644
--- a/liblwgeom/lwout_kml.c
+++ b/liblwgeom/lwout_kml.c
@@ -107,10 +107,10 @@ ptarray_to_kml2_sb(const POINTARRAY *pa, int precision, stringbuffer_t *sb)
getPoint4d_p(pa, i, &pt);
d = (double*)(&pt);
- if ( i ) stringbuffer_append(sb," ");
+ if ( i ) stringbuffer_append_len(sb," ",1);
for (j = 0; j < dims; j++)
- if ( j ) stringbuffer_append(sb,",");
+ if ( j ) stringbuffer_append_len(sb,",",1);
if( fabs(d[j]) < OUT_MAX_DOUBLE )
if ( stringbuffer_aprintf(sb, "%.*f", precision, d[j]) < 0 ) return LW_FAILURE;
diff --git a/liblwgeom/lwout_wkt.c b/liblwgeom/lwout_wkt.c
index ab05f6b..60b4bbd 100644
--- a/liblwgeom/lwout_wkt.c
+++ b/liblwgeom/lwout_wkt.c
@@ -46,19 +46,19 @@ static void dimension_qualifiers_to_wkt_sb(const LWGEOM *geom, stringbuffer_t *s
if ( (variant & WKT_EXTENDED) && FLAGS_GET_M(geom->flags) && (!FLAGS_GET_Z(geom->flags)) )
#endif
- stringbuffer_append(sb, "M"); /* "M" */
+ stringbuffer_append_len(sb, "M", 1); /* "M" */
return;
/* ISO WKT: POINT ZM (0 0 0 0) */
if ( (variant & WKT_ISO) && (FLAGS_NDIMS(geom->flags) > 2) )
- stringbuffer_append(sb, " ");
+ stringbuffer_append_len(sb, " ", 1);
if ( FLAGS_GET_Z(geom->flags) )
- stringbuffer_append(sb, "Z");
+ stringbuffer_append_len(sb, "Z", 1);
if ( FLAGS_GET_M(geom->flags) )
@@ -70,9 +70,9 @@ static void empty_to_wkt_sb(stringbuffer_t *sb)
if ( ! strchr(" ,(", stringbuffer_lastchar(sb)) ) /* "EMPTY" */
- stringbuffer_append(sb, "EMPTY");
+ stringbuffer_append_len(sb, "EMPTY", 5);
@@ -94,7 +94,7 @@ static void ptarray_to_wkt_sb(const POINTARRAY *ptarray, stringbuffer_t *sb, int
/* Opening paren? */
if ( ! (variant & WKT_NO_PARENS) )
- stringbuffer_append(sb, "(");
+ stringbuffer_append_len(sb, "(", 1);
/* Digits and commas */
for (i = 0; i < ptarray->npoints; i++)
@@ -103,13 +103,13 @@ static void ptarray_to_wkt_sb(const POINTARRAY *ptarray, stringbuffer_t *sb, int
/* Commas before ever coord but the first */
if ( i > 0 )
- stringbuffer_append(sb, ",");
+ stringbuffer_append_len(sb, ",", 1);
for (j = 0; j < dimensions; j++)
/* Spaces before every ordinate but the first */
if ( j > 0 )
lwprint_double(dbl_ptr[j],
precision,
coord,
@@ -120,7 +120,7 @@ static void ptarray_to_wkt_sb(const POINTARRAY *ptarray, stringbuffer_t *sb, int
/* Closing paren? */
- stringbuffer_append(sb, ")");
+ stringbuffer_append_len(sb, ")", 1);
@@ -137,7 +137,7 @@ static void lwpoint_to_wkt_sb(const LWPOINT *pt, stringbuffer_t *sb, int precisi
if ( ! (variant & WKT_NO_TYPE) )
- stringbuffer_append(sb, "POINT"); /* "POINT" */
+ stringbuffer_append_len(sb, "POINT", 5); /* "POINT" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)pt, sb, variant);
@@ -157,7 +157,7 @@ static void lwline_to_wkt_sb(const LWLINE *line, stringbuffer_t *sb, int precisi
- stringbuffer_append(sb, "LINESTRING"); /* "LINESTRING" */
+ stringbuffer_append_len(sb, "LINESTRING", 10); /* "LINESTRING" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)line, sb, variant);
if ( lwline_is_empty(line) )
@@ -177,7 +177,7 @@ static void lwpoly_to_wkt_sb(const LWPOLY *poly, stringbuffer_t *sb, int precisi
uint32_t i = 0;
- stringbuffer_append(sb, "POLYGON"); /* "POLYGON" */
+ stringbuffer_append_len(sb, "POLYGON", 7); /* "POLYGON" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)poly, sb, variant);
if ( lwpoly_is_empty(poly) )
@@ -186,14 +186,14 @@ static void lwpoly_to_wkt_sb(const LWPOLY *poly, stringbuffer_t *sb, int precisi
return;
for ( i = 0; i < poly->nrings; i++ )
if ( i > 0 )
ptarray_to_wkt_sb(poly->rings[i], sb, precision, variant);
@@ -203,7 +203,7 @@ static void lwcircstring_to_wkt_sb(const LWCIRCSTRING *circ, stringbuffer_t *sb,
- stringbuffer_append(sb, "CIRCULARSTRING"); /* "CIRCULARSTRING" */
+ stringbuffer_append_len(sb, "CIRCULARSTRING", 14); /* "CIRCULARSTRING" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)circ, sb, variant);
if ( lwcircstring_is_empty(circ) )
@@ -224,7 +224,7 @@ static void lwmpoint_to_wkt_sb(const LWMPOINT *mpoint, stringbuffer_t *sb, int p
uint32_t i = 0;
- stringbuffer_append(sb, "MULTIPOINT"); /* "MULTIPOINT" */
+ stringbuffer_append_len(sb, "MULTIPOINT", 10); /* "MULTIPOINT" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)mpoint, sb, variant);
if ( mpoint->ngeoms < 1 )
@@ -232,16 +232,16 @@ static void lwmpoint_to_wkt_sb(const LWMPOINT *mpoint, stringbuffer_t *sb, int p
empty_to_wkt_sb(sb);
return;
variant = variant | WKT_IS_CHILD; /* Inform the sub-geometries they are childre */
for ( i = 0; i < mpoint->ngeoms; i++ )
if ( i > 0 )
/* We don't want type strings or parens on our subgeoms */
lwpoint_to_wkt_sb(mpoint->geoms[i], sb, precision, variant | WKT_NO_PARENS | WKT_NO_TYPE );
@@ -253,7 +253,7 @@ static void lwmline_to_wkt_sb(const LWMLINE *mline, stringbuffer_t *sb, int prec
- stringbuffer_append(sb, "MULTILINESTRING"); /* "MULTILINESTRING" */
+ stringbuffer_append_len(sb, "MULTILINESTRING", 15); /* "MULTILINESTRING" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)mline, sb, variant);
if ( mline->ngeoms < 1 )
@@ -262,16 +262,16 @@ static void lwmline_to_wkt_sb(const LWMLINE *mline, stringbuffer_t *sb, int prec
return;
for ( i = 0; i < mline->ngeoms; i++ )
if ( i > 0 )
/* We don't want type strings on our subgeoms */
lwline_to_wkt_sb(mline->geoms[i], sb, precision, variant | WKT_NO_TYPE );
@@ -283,7 +283,7 @@ static void lwmpoly_to_wkt_sb(const LWMPOLY *mpoly, stringbuffer_t *sb, int prec
- stringbuffer_append(sb, "MULTIPOLYGON"); /* "MULTIPOLYGON" */
+ stringbuffer_append_len(sb, "MULTIPOLYGON", 12); /* "MULTIPOLYGON" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)mpoly, sb, variant);
if ( mpoly->ngeoms < 1 )
@@ -292,16 +292,16 @@ static void lwmpoly_to_wkt_sb(const LWMPOLY *mpoly, stringbuffer_t *sb, int prec
return;
for ( i = 0; i < mpoly->ngeoms; i++ )
if ( i > 0 )
lwpoly_to_wkt_sb(mpoly->geoms[i], sb, precision, variant | WKT_NO_TYPE );
@@ -315,7 +315,7 @@ static void lwcompound_to_wkt_sb(const LWCOMPOUND *comp, stringbuffer_t *sb, int
- stringbuffer_append(sb, "COMPOUNDCURVE"); /* "COMPOUNDCURVE" */
+ stringbuffer_append_len(sb, "COMPOUNDCURVE", 13); /* "COMPOUNDCURVE" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)comp, sb, variant);
if ( comp->ngeoms < 1 )
@@ -324,13 +324,13 @@ static void lwcompound_to_wkt_sb(const LWCOMPOUND *comp, stringbuffer_t *sb, int
return;
for ( i = 0; i < comp->ngeoms; i++ )
int type = comp->geoms[i]->type;
if ( i > 0 )
/* Linestring subgeoms don't get type identifiers */
if ( type == LINETYPE )
@@ -346,7 +346,7 @@ static void lwcompound_to_wkt_sb(const LWCOMPOUND *comp, stringbuffer_t *sb, int
lwerror("lwcompound_to_wkt_sb: Unknown type received %d - %s", type, lwtype_name(type));
@@ -360,7 +360,7 @@ static void lwcurvepoly_to_wkt_sb(const LWCURVEPOLY *cpoly, stringbuffer_t *sb,
- stringbuffer_append(sb, "CURVEPOLYGON"); /* "CURVEPOLYGON" */
+ stringbuffer_append_len(sb, "CURVEPOLYGON", 12); /* "CURVEPOLYGON" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)cpoly, sb, variant);
if ( cpoly->nrings < 1 )
@@ -368,13 +368,13 @@ static void lwcurvepoly_to_wkt_sb(const LWCURVEPOLY *cpoly, stringbuffer_t *sb,
return;
for ( i = 0; i < cpoly->nrings; i++ )
int type = cpoly->rings[i]->type;
if ( i > 0 )
switch (type)
case LINETYPE:
@@ -393,7 +393,7 @@ static void lwcurvepoly_to_wkt_sb(const LWCURVEPOLY *cpoly, stringbuffer_t *sb,
lwerror("lwcurvepoly_to_wkt_sb: Unknown type received %d - %s", type, lwtype_name(type));
@@ -408,7 +408,7 @@ static void lwmcurve_to_wkt_sb(const LWMCURVE *mcurv, stringbuffer_t *sb, int pr
- stringbuffer_append(sb, "MULTICURVE"); /* "MULTICURVE" */
+ stringbuffer_append_len(sb, "MULTICURVE", 10); /* "MULTICURVE" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)mcurv, sb, variant);
if ( mcurv->ngeoms < 1 )
@@ -416,13 +416,13 @@ static void lwmcurve_to_wkt_sb(const LWMCURVE *mcurv, stringbuffer_t *sb, int pr
return;
for ( i = 0; i < mcurv->ngeoms; i++ )
int type = mcurv->geoms[i]->type;
if ( i > 0 )
switch (type)
case LINETYPE:
@@ -441,7 +441,7 @@ static void lwmcurve_to_wkt_sb(const LWMCURVE *mcurv, stringbuffer_t *sb, int pr
lwerror("lwmcurve_to_wkt_sb: Unknown type received %d - %s", type, lwtype_name(type));
@@ -456,7 +456,7 @@ static void lwmsurface_to_wkt_sb(const LWMSURFACE *msurf, stringbuffer_t *sb, in
- stringbuffer_append(sb, "MULTISURFACE"); /* "MULTISURFACE" */
+ stringbuffer_append_len(sb, "MULTISURFACE", 12); /* "MULTISURFACE" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)msurf, sb, variant);
if ( msurf->ngeoms < 1 )
@@ -464,13 +464,13 @@ static void lwmsurface_to_wkt_sb(const LWMSURFACE *msurf, stringbuffer_t *sb, in
return;
for ( i = 0; i < msurf->ngeoms; i++ )
int type = msurf->geoms[i]->type;
if ( i > 0 )
switch (type)
case POLYGONTYPE:
@@ -485,7 +485,7 @@ static void lwmsurface_to_wkt_sb(const LWMSURFACE *msurf, stringbuffer_t *sb, in
lwerror("lwmsurface_to_wkt_sb: Unknown type received %d - %s", type, lwtype_name(type));
@@ -499,7 +499,7 @@ static void lwcollection_to_wkt_sb(const LWCOLLECTION *collection, stringbuffer_
- stringbuffer_append(sb, "GEOMETRYCOLLECTION"); /* "GEOMETRYCOLLECTION" */
+ stringbuffer_append_len(sb, "GEOMETRYCOLLECTION", 18); /* "GEOMETRYCOLLECTION" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)collection, sb, variant);
if ( collection->ngeoms < 1 )
@@ -507,15 +507,15 @@ static void lwcollection_to_wkt_sb(const LWCOLLECTION *collection, stringbuffer_
return;
variant = variant | WKT_IS_CHILD; /* Inform the sub-geometries they are children */
for ( i = 0; i < collection->ngeoms; i++ )
if ( i > 0 )
lwgeom_to_wkt_sb((LWGEOM*)collection->geoms[i], sb, precision, variant );
@@ -525,7 +525,7 @@ static void lwtriangle_to_wkt_sb(const LWTRIANGLE *tri, stringbuffer_t *sb, int
- stringbuffer_append(sb, "TRIANGLE"); /* "TRIANGLE" */
+ stringbuffer_append_len(sb, "TRIANGLE", 8); /* "TRIANGLE" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)tri, sb, variant);
if ( lwtriangle_is_empty(tri) )
@@ -534,9 +534,9 @@ static void lwtriangle_to_wkt_sb(const LWTRIANGLE *tri, stringbuffer_t *sb, int
return;
- stringbuffer_append(sb, "("); /* Triangles have extraneous brackets */
+ stringbuffer_append_len(sb, "(", 1); /* Triangles have extraneous brackets */
ptarray_to_wkt_sb(tri->points, sb, precision, variant);
@@ -548,7 +548,7 @@ static void lwtin_to_wkt_sb(const LWTIN *tin, stringbuffer_t *sb, int precision,
- stringbuffer_append(sb, "TIN"); /* "TIN" */
+ stringbuffer_append_len(sb, "TIN", 3); /* "TIN" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)tin, sb, variant);
if ( tin->ngeoms < 1 )
@@ -557,15 +557,15 @@ static void lwtin_to_wkt_sb(const LWTIN *tin, stringbuffer_t *sb, int precision,
return;
for ( i = 0; i < tin->ngeoms; i++ )
if ( i > 0 )
lwtriangle_to_wkt_sb(tin->geoms[i], sb, precision, variant | WKT_NO_TYPE );
@@ -577,7 +577,7 @@ static void lwpsurface_to_wkt_sb(const LWPSURFACE *psurf, stringbuffer_t *sb, in
- stringbuffer_append(sb, "POLYHEDRALSURFACE"); /* "POLYHEDRALSURFACE" */
+ stringbuffer_append_len(sb, "POLYHEDRALSURFACE", 17); /* "POLYHEDRALSURFACE" */
dimension_qualifiers_to_wkt_sb((LWGEOM*)psurf, sb, variant);
if ( psurf->ngeoms < 1 )
@@ -588,15 +588,15 @@ static void lwpsurface_to_wkt_sb(const LWPSURFACE *psurf, stringbuffer_t *sb, in
for ( i = 0; i < psurf->ngeoms; i++ )
if ( i > 0 )
lwpoly_to_wkt_sb(psurf->geoms[i], sb, precision, variant | WKT_NO_TYPE );
diff --git a/liblwgeom/lwout_x3d.c b/liblwgeom/lwout_x3d.c
index bfb1bf8..f126561 100644
--- a/liblwgeom/lwout_x3d.c
+++ b/liblwgeom/lwout_x3d.c
@@ -521,7 +521,7 @@ ptarray_to_x3d3_sb(POINTARRAY *pa, int precision, int opts, int is_closed, strin
lwprint_double(
pt.y, precision, y, OUT_DOUBLE_BUFFER_SIZE);
if ( ( opts & LW_X3D_FLIP_XY) )
stringbuffer_aprintf(sb, "%s %s", y, x);
@@ -547,7 +547,7 @@ ptarray_to_x3d3_sb(POINTARRAY *pa, int precision, int opts, int is_closed, strin
lwprint_double(
pt.z, precision, z, OUT_DOUBLE_BUFFER_SIZE);
stringbuffer_aprintf(sb, "%s %s %s", y, x, z);
diff --git a/liblwgeom/stringbuffer.h b/liblwgeom/stringbuffer.h
index bead7c9..1a2d519 100644
--- a/liblwgeom/stringbuffer.h
+++ b/liblwgeom/stringbuffer.h
@@ -81,16 +81,27 @@ stringbuffer_makeroom(stringbuffer_t *s, size_t size_to_add)
s->str_end = s->str_start + current_size;
- * Append the specified string to the stringbuffer_t.
+ * Append the specified string to the stringbuffer_t using known length
inline static void
-stringbuffer_append(stringbuffer_t *s, const char *a)
+stringbuffer_append_len(stringbuffer_t *s, const char *a, size_t alen)
- int alen = strlen(a); /* Length of string to append */
int alen0 = alen + 1; /* Length including null terminator */
stringbuffer_makeroom(s, alen0);
memcpy(s->str_end, a, alen0);
s->str_end += alen;
+ * Append the specified string to the stringbuffer_t.
+inline static void
+stringbuffer_append(stringbuffer_t *s, const char *a)
+ int alen = strlen(a); /* Length of string to append */
+ stringbuffer_append_len(s, a, alen);
#endif /* _STRINGBUFFER_H */
Summary of changes:
liblwgeom/lwout_kml.c | 4 +-
liblwgeom/lwout_wkt.c | 122 +++++++++++++++++++++++------------------------
liblwgeom/lwout_x3d.c | 4 +-
liblwgeom/stringbuffer.h | 17 +++++--
4 files changed, 79 insertions(+), 68 deletions(-)
hooks/post-receive
