[postgis-tickets] [PostGIS] #4386: [upgrade] ERROR: cannot drop function st_union(geometry) because other objects depend on it
PostGIS trac at osgeo.org
Thu Mar 5 02:51:12 PST 2020
  Reporter:  strk                   |      Owner:  komzpa
      Type:  defect                 |     Status:  reopened
  Priority:  blocker                |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Changes (by strk):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
 The test does NOT close this ticket, it just makes it tested.
 See https://dronie.osgeo.org/postgis/postgis/1098/1/2
 Example broken upgrade path: 2.1.9--3.1.0dev
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4386#comment:18>
