[postgis-tickets] [SCM] PostGIS branch stable-2.3 updated. 5586322781f356abccd4340453f811dd810de941
Thu Mar 26 07:35:08 PDT 2020
the project "PostGIS".
The branch, stable-2.3 has been updated
       via  5586322781f356abccd4340453f811dd810de941 (commit)
      from  22a0333906ff36aecb0bf7c4dc822eec7aca6cdb (commit)
revisions in full, below.
commit 5586322781f356abccd4340453f811dd810de941
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Mar 26 10:34:51 2020 -0400
    Change ogc line intersection test to one that sfcgal will always give same answer regardless of version of sfcgal
diff --git a/regress/core/Makefile b/regress/core/Makefile
new file mode 100644
index 0000000..b54cc70
--- /dev/null
+++ b/regress/core/Makefile
@@ -0,0 +1,240 @@
+# * PostGIS - Spatial Types for PostgreSQL
+# * http://postgis.net
+# * Copyright (C) 2011-2012 Sandro Santilli <strk at kbt.io>
+# * Copyright (C) 2009-2011 Paul Ramsey <pramsey at cleverelephant.ca>
+# * Copyright (C) 2008-2009 Mark Cave-Ayland
+# * This is free software; you can redistribute and/or modify it under
+# * the terms of the GNU General Public Licence. See the COPYING file.
+PERL=/usr/bin/perl
+TMPDIR?=/tmp
+POSTGIS_PGSQL_VERSION=120
+POSTGIS_GEOS_VERSION=39
+GEOS_NUMERIC_VERSION=30900
+POSTGIS_PROJ_VERSION=62
+POSTGIS_MAJOR_VERSION=3
+POSTGIS_MINOR_VERSION=1
+HAVE_JSON=yes
+PROTOC_VERSION=1002001
+HAVE_SPGIST=yes
+INTERRUPTTESTS=no
+# MingW hack: rather than use PGSQL_BINDIR directly, we change
+# to the directory and then use "pwd" to return the path. This
+# ensures that the returned path is in MSYS format, otherwise
+# colons in drive letters will break PATH.
+PGSQL_BINDIR=$(shell cd "C:/MING64~1/projects/POSTGR~1/rel/PG12W6~4/bin" && pwd)
+# Put path from pg_config into front of search path
+PATH := $(PGSQL_BINDIR):$(PATH)
+export PATH
+TESTS = \
+	../loader/Point \
+	../loader/PointM \
+	../loader/PointZ \
+	../loader/MultiPoint \
+	../loader/MultiPointM \
+	../loader/MultiPointZ \
+	../loader/Arc \
+	../loader/ArcM \
+	../loader/ArcZ \
+	../loader/Polygon \
+	../loader/PolygonM \
+	../loader/PolygonZ \
+	../loader/TSTPolygon \
+	../loader/TSIPolygon \
+	../loader/TSTIPolygon \
+	../loader/PointWithSchema \
+	../loader/NoTransPoint \
+	../loader/NotReallyMultiPoint \
+	../loader/MultiToSinglePoint \
+	../loader/ReprojectPts \
+	../loader/ReprojectPtsD \
+	../loader/ReprojectPtsGeog \
+	../loader/ReprojectPtsGeogD \
+	../loader/Latin1 \
+	../loader/Latin1-implicit \
+	../loader/mfile \
+	../dumper/literalsrid \
+	../dumper/realtable \
+	../dumper/nullsintable \
+	../dumper/null3d \
+	affine \
+	bestsrid \
+	binary \
+	boundary \
+	chaikin \
+	filterm \
+	cluster \
+	concave_hull\
+	ctors \
+	curvetoline \
+	dump \
+	dumppoints \
+	empty \
+	estimatedextent \
+	forcecurve \
+	geography \
+	geometric_median \
+	hausdorff \
+	in_geohash \
+	in_gml \
+	in_kml \
+	in_encodedpolyline \
+	iscollection \
+	legacy \
+	long_xact \
+	lwgeom_regress \
+	measures \
+	minimum_bounding_circle \
+	normalize \
+	operators \
+	orientation \
+	out_geometry \
+	out_geography \
+	polygonize \
+	polyhedralsurface \
+	postgis_type_name \
+	quantize_coordinates \
+	regress \
+	regress_bdpoly \
+	regress_buffer_params \
+	regress_gist_index_nd \
+	regress_index \
+	regress_index_nulls \
+	regress_management \
+	regress_selectivity \
+	regress_lrs \
+	regress_ogc \
+	regress_ogc_cover \
+	regress_ogc_prep \
+	regress_proj \
+	relate \
+	remove_repeated_points \
+	removepoint \
+	reverse \
+	setpoint \
+	simplify \
+	simplifyvw \
+	size \
+	snaptogrid \
+	split \
+	sql-mm-serialize \
+	sql-mm-circularstring \
+	sql-mm-compoundcurve \
+	sql-mm-curvepoly \
+	sql-mm-general \
+	sql-mm-multicurve \
+	sql-mm-multisurface \
+	swapordinates \
+	summary \
+	temporal \
+	temporal_knn \
+	tickets \
+	twkb \
+	typmod \
+	wkb \
+	wkt \
+	wmsservers \
+	offsetcurve \
+	relatematch \
+	isvaliddetail \
+	sharedpaths \
+	snap \
+	node \
+	unaryunion \
+	clean \
+	relate_bnr \
+	delaunaytriangles \
+	clipbybox2d \
+	subdivide \
+	voronoi \
+	regress_brin_index \
+	regress_brin_index_3d \
+	regress_brin_index_geography \
+	minimum_clearance \
+	oriented_envelope \
+	point_coordinates
+# Slow slow tests
+TESTS_SLOW = \
+	concave_hull_hard \
+	knn_recheck
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 37),1)
+	# GEOS-3.7 adds:
+	# ST_FrechetDistance
+	TESTS += \
+		frechet
+endif
+ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 38),1)
+	# GEOS-3.8 adds stable pointonsurface implementation
+	TESTS += \
+		geos38
+endif
+ifeq ($(INTERRUPTTESTS),yes)
+	# Allow CI servers to configure --with-interrupt-tests
+	TESTS += \
+		interrupt \
+		interrupt_relate \
+		interrupt_buffer
+endif
+ifeq ($(HAVE_JSON),yes)
+	# JSON-C adds:
+	# ST_GeomFromGeoJSON()
+	TESTS += \
+		in_geojson
+endif
+ifeq ($(HAVE_SPGIST),yes)
+	TESTS += \
+	regress_spgist_index_2d \
+	regress_spgist_index_3d \
+	regress_spgist_index_nd
+endif
+ifeq (yes,yes)
+	# protobuf-c adds:
+	# ST_AsMVT, ST_AsGeobuf
+	TESTS += \
+		mvt \
+		mvt_jsonb
+ifeq (yes,yes)
+	TESTS += \
+		geobuf
+endif
+endif
+all install uninstall:
+distclean: clean
+	rm Makefile
+test check:
+	$(PERL) ../run_test.pl $(RUNTESTFLAGS) $(TESTS)
+	# only run upgrade test if RUNTESTFLAGS was not already doing that
+	if echo "$(RUNTESTFLAGS)" | grep -vq -- --upgrade; then \
+		$(PERL) ../run_test.pl --upgrade $(RUNTESTFLAGS) $(TESTS); \
+	fi
+check-long:
+	$(PERL) ../run_test.pl $(RUNTESTFLAGS) $(TESTS) $(TESTS_SLOW)
+clean:
diff --git a/regress/regress_ogc.sql b/regress/regress_ogc.sql
index e53e373..a4d25e8 100644
--- a/regress/regress_ogc.sql
+++ b/regress/regress_ogc.sql
@@ -157,7 +157,7 @@ SELECT 'overlaps', ST_overlaps('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'::geometr
 SELECT 'isvalid', ST_isvalid('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'::geometry);
 SELECT 'isvalid', ST_isvalid('POLYGON((0 0, 0 10, 10 10, -5 10, 10 0, 0 0))'::geometry);
 SELECT 'isvalid', ST_isvalid('GEOMETRYCOLLECTION EMPTY'::geometry);
-SELECT 'intersection', ST_astext(ST_intersection('LINESTRING(0 10, 0 -10)'::geometry, 'LINESTRING(0 0, 1 1)'::geometry));
+SELECT 'intersection', ST_astext(ST_intersection('LINESTRING(0 10, 0 -10, 0 5)'::geometry, 'LINESTRING(0 1, 1 1)'::geometry));
 SELECT 'difference', ST_astext(ST_difference('LINESTRING(0 10, 0 -10)'::GEOMETRY, 'LINESTRING(0 2, 0 -2)'::GEOMETRY));
 SELECT 'boundary', ST_astext(ST_boundary('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(2 2, 2 4, 4 4, 4 2, 2 2))'::geometry));
 SELECT 'symdifference', ST_astext(ST_symdifference('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0),(2 2, 2 4, 4 4, 4 2, 2 2))'::geometry, 'LINESTRING(0 0, 20 20)'::geometry));
diff --git a/regress/regress_ogc_expected b/regress/regress_ogc_expected
index 5ab5f91..06a517a 100644
--- a/regress/regress_ogc_expected
+++ b/regress/regress_ogc_expected
@@ -88,7 +88,7 @@ isvalid|t
 NOTICE:  Self-intersection
 isvalid|f
 isvalid|t
-intersection|POINT(0 0)
+intersection|POINT(0 1)
 difference|MULTILINESTRING((0 10,0 2),(0 -2,0 -10))
 boundary|MULTILINESTRING((0 0,0 10,10 10,10 0,0 0),(2 2,2 4,4 4,4 2,2 2))
 symdifference|GEOMETRYCOLLECTION(LINESTRING(2 2,4 4),LINESTRING(10 10,20 20),POLYGON((0 0,0 10,10 10,10 0,0 0),(4 4,2 4,2 2,4 2,4 4)))
diff --git a/regress/sfcgal/Makefile b/regress/sfcgal/Makefile
index 0000000..1494275
--- /dev/null
+++ b/regress/sfcgal/Makefile
@@ -0,0 +1,57 @@
+PERL=/usr/bin/perl
+TMPDIR?=/tmp
+HAVE_SFCGAL=yes
+ifeq ($(HAVE_SFCGAL),yes)
+export PATH
+TESTS = \
+		regress_sfcgal \
+		approximatemedialaxis.sql
+test check:
+	$(PERL) ../run_test.pl --sfcgal $(RUNTESTFLAGS) $(TESTS)
+		$(PERL) ../run_test.pl --sfcgal --upgrade $(RUNTESTFLAGS) $(TESTS); \
+	fi
+else
+check:
+endif # HAVE_SFCGAL
+distclean: clean
+	rm Makefile
+clean:
diff --git a/regress/sfcgal/regress_ogc_expected b/regress/sfcgal/regress_ogc_expected
index 65205fc..ee98579 100644
--- a/regress/sfcgal/regress_ogc_expected
+++ b/regress/sfcgal/regress_ogc_expected
 isvalid|f
 isvalid|t
-intersection|POINT(-0 -0)
 difference|MULTILINESTRING((0 -2,0 -10),(0 10,0 2))
Summary of changes:
 regress/core/Makefile               | 240 ++++++++++++++++++++++++++++++++++++
 regress/regress_ogc.sql             |   2 +-
 regress/regress_ogc_expected        |   2 +-
 regress/sfcgal/Makefile             |  57 +++++++++
 regress/sfcgal/regress_ogc_expected |   2 +-
 5 files changed, 300 insertions(+), 3 deletions(-)
 create mode 100644 regress/core/Makefile
 create mode 100644 regress/sfcgal/Makefile
hooks/post-receive
