[postgis-tickets] [PostGIS] #4652: Postgres crash with ST_GeomFromGML
trac at osgeo.org
Fri Mar 27 08:09:15 PDT 2020
Reporter: mwjhartogs | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone:
Component: postgis | Version: 2.5.x
Resolution: | Keywords: ST_GeomFromGML
Comment (by Algunenano):
Call stack without any optimizations (neither PG nor Postgis):
(gdb) bt
#0 0x00007fba0f042ce5 in raise () from /usr/lib/libc.so.6
#1 0x00007fba0f02c857 in abort () from /usr/lib/libc.so.6
#2 0x00007fba0f0862b0 in __libc_message () from /usr/lib/libc.so.6
#3 0x00007fba0f08d74a in malloc_printerr () from /usr/lib/libc.so.6
#4 0x00007fba0f0906b4 in _int_malloc () from /usr/lib/libc.so.6
#5 0x00007fba0f091e74 in malloc () from /usr/lib/libc.so.6
#6 0x0000559e4bc1d52e in AllocSetAlloc (context=0x559e4c58b6e0, size=128)
at aset.c:914
#7 0x0000559e4bc29d71 in MemoryContextAllocZeroAligned
(context=0x559e4c58b6e0, size=128) at mcxt.c:864
#8 0x0000559e4b8c2feb in standard_planner (parse=0x559e4c58c928,
cursorOptions=256, boundParams=0x0) at planner.c:298
#9 0x0000559e4b8c2fae in planner (parse=0x559e4c58c928,
cursorOptions=256, boundParams=0x0) at planner.c:275
#10 0x0000559e4ba0510c in pg_plan_query (querytree=0x559e4c58c928,
cursorOptions=256, boundParams=0x0) at postgres.c:878
#11 0x0000559e4ba05270 in pg_plan_queries (querytrees=0x559e4c58d698,
cursorOptions=256, boundParams=0x0) at postgres.c:968
#12 0x0000559e4bbc58b6 in BuildCachedPlan (plansource=0x559e4c58c698,
qlist=0x559e4c58d698, boundParams=0x0, queryEnv=0x0) at plancache.c:933
#13 0x0000559e4bbc4db7 in GetCachedPlan (plansource=0x559e4c58c698,
boundParams=0x0, useResOwner=false, queryEnv=0x0) at plancache.c:1214
#14 0x0000559e4b7ff3ad in _SPI_execute_plan (plan=0x7ffe8b63d5d0,
paramLI=0x0, snapshot=0x0, crosscheck_snapshot=0x0, read_only=false,
fire_triggers=true, tcount=1) at spi.c:2215
#15 0x0000559e4b7fef4b in SPI_execute (src=0x7ffe8b63d660 "SELECT
position('+units=m ' in proj4text)", ' ' <repeats 25 times>, "FROM
spatial_ref_sys WHERE srid='28992'", read_only=false, tcount=1) at
spi.c:514
#16 0x0000559e4b7ffbd1 in SPI_exec (src=0x7ffe8b63d660 "SELECT
spatial_ref_sys WHERE srid='28992'", tcount=1) at spi.c:526
#17 0x00007fb7feb59274 in gml_is_srid_planar (srid=28992) at
lwgeom_in_gml.c:397
#18 0x00007fb7feb56ccd in parse_gml_srs (xnode=0x559e4c558c30,
srs=0x7ffe8b63d850) at lwgeom_in_gml.c:487
#19 0x00007fb7feb57455 in parse_gml_curve (xnode=0x559e4c558c30,
hasz=0x7ffe8b63d917, root_srid=0x7ffe8b63d910) at lwgeom_in_gml.c:1138
#20 0x00007fb7feb565e4 in parse_gml (xnode=0x559e4c558c30,
hasz=0x7ffe8b63d917, root_srid=0x7ffe8b63d910) at lwgeom_in_gml.c:1933
#21 0x00007fb7feb563a5 in lwgeom_from_gml (
xml=0x559e4c55cdf0 "<gml:Curve id=\"id-
69b216c9-2c07-434d-8664-e321b3697725-0\" srsDimension=\"2\"
srsName=\"urn:x-ogc:def:crs:EPSG:28992\"> <gml:segments>
<gml:LineStringSegment> \n<gml:posList>119675.91899999976
526436.120999"..., xml_size=13248)
at lwgeom_in_gml.c:1877
#22 0x00007fb7feb56276 in geom_from_gml (fcinfo=0x559e4c5424d0) at
lwgeom_in_gml.c:116
#23 0x0000559e4b798735 in ExecInterpExpr (state=0x559e4c5423e0,
econtext=0x559e4c542620, isnull=0x7ffe8b63dc87) at execExprInterp.c:649
#24 0x0000559e4b7979d7 in ExecInterpExprStillValid (state=0x559e4c5423e0,
econtext=0x559e4c542620, isNull=0x7ffe8b63dc87) at execExprInterp.c:1778
#25 0x0000559e4b8ec46b in ExecEvalExprSwitchContext (state=0x559e4c5423e0,
../../../../src/include/executor/executor.h:307
#26 0x0000559e4b8ec31f in evaluate_expr (expr=0x559e4c4762b8,
result_type=72111, result_typmod=-1, result_collation=0) at clauses.c:4812
#27 0x0000559e4b8ee0e9 in evaluate_function (funcid=72624,
result_type=72111, result_typmod=-1, result_collid=0, input_collid=100,
args=0x559e4c476200, funcvariadic=false, func_tuple=0x7fb7fecf1ed0,
context=0x7ffe8b63fa80) at clauses.c:4354
#28 0x0000559e4b8ed388 in simplify_function (funcid=72624,
args_p=0x7ffe8b63e328, funcvariadic=false, process_args=true,
allow_non_const=true, context=0x7ffe8b63fa80)
at clauses.c:3984
#29 0x0000559e4b8e939b in eval_const_expressions_mutator
(node=0x559e4c475ed8, context=0x7ffe8b63fa80) at clauses.c:2477
#30 0x0000559e4b8352ff in expression_tree_mutator (node=0x559e4c475f30,
mutator=0x559e4b8e8e70 <eval_const_expressions_mutator>,
context=0x7ffe8b63fa80) at nodeFuncs.c:2963
#31 0x0000559e4b8eb86f in eval_const_expressions_mutator
(node=0x559e4c475f30, context=0x7ffe8b63fa80) at clauses.c:3539
#32 0x0000559e4b835514 in expression_tree_mutator (node=0x559e4c475718,
context=0x7ffe8b63fa80) at nodeFuncs.c:3012
#33 0x0000559e4b8eb86f in eval_const_expressions_mutator
(node=0x559e4c475718, context=0x7ffe8b63fa80) at clauses.c:3539
#34 0x0000559e4b8e8e3e in eval_const_expressions (root=0x559e4c474508,
node=0x559e4c475718) at clauses.c:2269
#35 0x0000559e4b8c4ca8 in preprocess_expression (root=0x559e4c474508,
expr=0x559e4c475718, kind=1) at planner.c:1087
#36 0x0000559e4b8c3e8a in subquery_planner (glob=0x559e4c475aa8,
parse=0x559e4c475448, parent_root=0x0, hasRecursion=false,
tuple_fraction=0) at planner.c:769
#37 0x0000559e4b8c3216 in standard_planner (parse=0x559e4c475448,
cursorOptions=256, boundParams=0x0) at planner.c:406
#38 0x0000559e4b8c2fae in planner (parse=0x559e4c475448,
#39 0x0000559e4ba0510c in pg_plan_query (querytree=0x559e4c475448,
#40 0x0000559e4ba05270 in pg_plan_queries (querytrees=0x559e4c476050,
#41 0x0000559e4ba07ddb in exec_simple_query (
query_string=0x559e4c49dbd0 "select ST_GeomFromGML('<gml:Curve id
=\"id-69b216c9-2c07-434d-8664-e321b3697725-0\" srsDimension=\"2\"
<gml:LineStringSegment> \n<gml:posList>119675.91"...)
at postgres.c:1143
#42 0x0000559e4ba072ed in PostgresMain (argc=1, argv=0x559e4c4a5928,
dbname=0x559e4c4a5778 "template_postgis", username=0x559e4c4a5750
"postgres") at postgres.c:4247
#43 0x0000559e4b9374bf in BackendRun (port=0x559e4c499e10) at
postmaster.c:4437
#44 0x0000559e4b936884 in BackendStartup (port=0x559e4c499e10) at
postmaster.c:4128
#45 0x0000559e4b935736 in ServerLoop () at postmaster.c:1704
#46 0x0000559e4b932f24 in PostmasterMain (argc=3, argv=0x559e4c46e230) at
postmaster.c:1377
#47 0x0000559e4b82eee1 in main (argc=3, argv=0x559e4c46e230) at main.c:228
The fact that it is crashing in an internal allocation (inside
pg_plan_query) points to a possible Postgresql bug, but it's not obvious
to me why calling malloc(8192) might crash like this:
(gdb) f 6
at aset.c:914
warning: Source file is more recent than executable.
914 block = (AllocBlock) malloc(blksize);
(gdb) p blksize
$1 = 8192
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4652#comment:3>
