[postgis-tickets] [PostGIS] #4654: Analyze regress tests with valgrind
PostGIS trac at osgeo.org
Fri Mar 27 12:34:26 PDT 2020
 Reporter:  Algunenano   |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  high         |  Milestone:  PostGIS 3.1.0
Component:  postgis      |    Version:  master
 Keywords:               |
 After https://trac.osgeo.org/postgis/ticket/4652 it seems obvious to me
 there is a need to run the regression tests, either once or ideally as
 part of the CI, under valgrind to detect issues.
 I've done a test and got multiple worrisome errors
 There are some around computing stats:
 mar 27 20:25:24 Mordor postgres[396099]: ==396099== Conditional jump or
 move depends on uninitialised value(s)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    at 0x813D16B:
 gbox_is_valid (gbox.c:221)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    by 0x80C864B:
 compute_gserialized_stats_mode (gserialized_estimate.c:1469)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    by 0x3FCD5A:
 do_analyze_rel (analyze.c:529)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    by 0x3FBC9C:
 analyze_rel (analyze.c:260)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    by 0x4BF51E: vacuum
 (vacuum.c:413)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    by 0x4BEDA6:
 ExecVacuum (vacuum.c:199)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    by 0x745296:
 standard_ProcessUtility (utility.c:670)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    by 0x744933:
 ProcessUtility (utility.c:360)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    by 0x74426A:
 PortalRunUtility (pquery.c:1175)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    by 0x7434A1:
 PortalRunMulti (pquery.c:1321)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    by 0x742ADD:
 PortalRun (pquery.c:796)
 mar 27 20:25:24 Mordor postgres[396099]: ==396099==    by 0x73DFD2:
 exec_simple_query (postgres.c:1215)
 mar 27 20:21:18 Mordor postgres[395155]: ==395155== Conditional jump or
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    at 0x81184B1:
 next_float_down (lwgeom_api.c:63)
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    by 0x813E720:
 gbox_float_round (gbox.c:784)
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    by 0x8141584:
 gserialized2_get_gbox_p (gserialized2.c:601)
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    by 0x80C861B:
 compute_gserialized_stats_mode (gserialized_estimate.c:1457)
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    by 0x80C6351:
 compute_gserialized_stats (gserialized_estimate.c:1871)
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    by 0x3FCD5A:
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    by 0x3FBC9C:
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    by 0x4BF51E: vacuum
 (vacuum.c:413)
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    by 0x4BEDA6:
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    by 0x745296:
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    by 0x744933:
 mar 27 20:21:18 Mordor postgres[395155]: ==395155==    by 0x74426A:
 This one seem like a cast:
 mar 27 20:23:26 Mordor postgres[395843]: ==395843== Conditional jump or
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    at 0x813D39B:
 gbox_merge (gbox.c:276)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    by 0x81470E9:
 lwcollection_calculate_gbox_geodetic (lwgeodetic.c:3020)
 lwgeom_calculate_gbox_geodetic (lwgeodetic.c:3056)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    by 0x81418E0:
 gserialized2_from_lwgeom (gserialized2.c:1179)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    by 0x8109068:
 geography_serialize (lwgeom_pg.c:305)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    by 0x80CAA3E:
 gserialized_geography_from_lwgeom (geography_inout.c:115)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    by 0x80CAB91:
 geography_in (geography_inout.c:177)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    by 0x9240F5:
 InputFunctionCall (fmgr.c:1548)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    by 0x9244C7:
 OidInputFunctionCall (fmgr.c:1651)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    by 0x3E867A:
 stringTypeDatum (parse_type.c:659)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    by 0x3C2459:
 coerce_type (parse_coerce.c:304)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    by 0x3C1E25:
 coerce_to_target_type (parse_coerce.c:103)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    by 0x3E4770:
 transformAssignedExpr (parse_target.c:577)
 mar 27 20:23:26 Mordor postgres[395843]: ==395843==    at 0x813D3AC:
 gbox_merge (gbox.c:277)
 Right now I get quite a bit of warnings from Postgresql syscalls (mostly
 the same one repeated over and over), so I first need to filter those out,
 and then find errors and match them with the queries that triggered them.
 The tests become really slow under valgrind, so I'm not sure how to best
 approach them (probably test each file independently).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4654>
