[postgis-tickets] [PostGIS] #4652: Postgres crash with ST_GeomFromGML
PostGIS trac at osgeo.org
Mon Mar 30 14:01:13 PDT 2020
  Reporter:  mwjhartogs  |      Owner:  pramsey
      Type:  defect      |     Status:  closed
  Priority:  critical    |  Milestone:
 Component:  postgis     |    Version:  2.5.x
Resolution:  fixed       |   Keywords:  ST_GeomFromGML
Comment (by pramsey):
 Running the #4652 test under OSX I'm seeing a complaint from PgSQL. Have
 you build your PgSQL --with-cassert?
 WARNING:  detected write past chunk end in ExprContext 0x7fe6b280af18
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4652#comment:15>
