[postgis-tickets] [PostGIS] #4652: Postgres crash with ST_GeomFromGML
PostGIS trac at osgeo.org
Mon Mar 30 14:10:49 PDT 2020
  Reporter:  mwjhartogs  |      Owner:  pramsey
      Type:  defect      |     Status:  reopened
  Priority:  critical    |  Milestone:
 Component:  postgis     |    Version:  2.5.x
Resolution:              |   Keywords:  ST_GeomFromGML
Comment (by Algunenano):
 > Running the #4652 test under OSX I'm seeing a complaint from PgSQL. Have
 you build your PgSQL --with-cassert?
 Yes, I added `--enable-cassert --enable-debug` to my build and I was
 seeing a similar error before the patch. After the patch I was getting
 only xml warnings IIRC; I'll try again to confirm it's gone.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4652#comment:17>
