[postgis-tickets] [PostGIS] #4655: TIGER 'addrfeat' table definition vs. current 2019 shapefiles
PostGIS trac at osgeo.org
Tue Mar 31 10:04:37 PDT 2020
  Reporter:  jlrobins        |      Owner:  robe
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:
 Component:  tiger geocoder  |    Version:  3.0.x
Resolution:                  |   Keywords:
Comment (by jlrobins):
 Replying to [comment:3 robe]:
 Absolutely nothing at this point. Having manually imported ~2012-era
 census boundaries manually in my prior shop, and realizing just what a
 chore it was, I was excited to start out with someone else's repeatable
 efforts and then pick through the results to figure out what layers I'd
 like to keep. So I started from the perspective of 'import every possible
 layer; sort 'em out later.'
 So at this point take it as advisement that some written code isn't
 working as hoped, regardless of its possible utility.
 Thanks!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4655#comment:4>
