[postgis-tickets] [PostGIS] #4685: Error upgrading postGIS from 2.4.4 to 2.5.4 on postgres 10.12
trac at osgeo.org
Tue May 5 11:21:13 PDT 2020
Reporter: sjezewskisf | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.5.x
Keywords: |
Hi there -
It seems like there is a regression of this bug:
https://trac.osgeo.org/postgis/ticket/3683?cversion=0&cnum_hist=1
I work at Heroku where we offer postgres as a service for millions of
databases. We offer postGIS support as a beta feature.
Some customers are experiencing problems upgrading from postgres 10.12
with postGIS 2.4.4
The specific error we see is:
sql_error_code = 00000 LOG: statement: ALTER EXTENSION "postgis" UPDATE;
sql_error_code = 01000 CONTEXT: SQL statement "SELECT
postgis_lib_version()"
PL/pgSQL function postgis_major_version_check() line 21 at SQL
statement
sql_error_code = 42883 ERROR: operator does not exist: gidx public.&&
geography at character 11
sql_error_code = 42883 HINT: No operator matches the given name and
argument type(s). You might need to add explicit type casts.
sql_error_code = 42883 QUERY: SELECT $2 OPERATOR(public.&&) $1;
The version of postGIS that its attempting to upgrade to is 2.5.4
We have many customers using postGIS 2.4.4 and they will be unable to
upgrade (their PG versions) until this is fixed.
It seems like we see postGIS upgrading errors from time to time like this.
Do you all have a test matrix that provides clarity on which versions /
upgrade paths are supported?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4685>
