[postgis-tickets] [PostGIS] #4691: Segfault when creating an index on geography(Point, 4326) column that contains empty points
trac at osgeo.org
Wed May 20 03:12:03 PDT 2020
Reporter: aktiur | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone:
Component: postgis | Version: 2.5.x
Keywords: |
When creating a gist index on a geography(Point, 4326) column that happens
to contain empty points (with coordinates of [nan, nan]), PostGIS will
sometimes encounter a segmentation fault when freeing some memory.
This is not a fully deterministic error. I'm joining a dataset with 11000
points (of which 1000 are empty, the other 10000 are gaussian distributed
around the center of France) and a script that imports it that seems to
trigger that bug most of the time, but in some circumstances there is no
segfault and I have to DROP the table and try again from the beginning to
trigger it again (truncating is not enough).
I did not manage to trigger the bug with a smaller dataset with only 1100
points.
I also noticed replacing the column type with geometry does not seem to
trigger the segfault, but I did not try with a bigger dataset.
I also joined a full stacktrace.
#!sql
crash_test=# SELECT version();
version
PostgreSQL 12.2 (Ubuntu 12.2-4) on x86_64-pc-linux-gnu, compiled by gcc
(Ubuntu 9.3.0-8ubuntu1) 9.3.0, 64-bit
(1 row)
crash_test=# SELECT postgis_full_version();
POSTGIS="3.0.0 r17983" [EXTENSION] PGSQL="120" GEOS="3.8.0-CAPI-1.13.1 "
PROJ="6.3.1" LIBXML="2.9.4" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3"
WAGYU="0.4.3 (Internal)"
(1 row)
I'm using PostGIS 3 but it seems to be the same bug as this
[https://www.postgresql.org/message-
id/16283-89418c2816e96f07%40postgresql.org Postgresql ticket #16283] where
the reporter was using PostGIS 2.5.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4691>
