[postgis-tickets] [SCM] PostGIS branch stable-2.3 updated. 24b01bda5ab45832b8a2f8902209f626dd14c602
git at osgeo.org
git at osgeo.org
Sun May 31 11:28:02 PDT 2020
the project "PostGIS".
The branch, stable-2.3 has been updated
via 24b01bda5ab45832b8a2f8902209f626dd14c602 (commit)
from 18b19fe0c3570f3dd28e843901cb2ee6784ec5b9 (commit)
revisions in full, below.
commit 24b01bda5ab45832b8a2f8902209f626dd14c602
Author: Regina Obe <lr at pcorp.us>
Date: Sun May 31 14:27:58 2020 -0400
Prepare for EOL 2.3.11, change make dist to use version of gdal installed on debbie do can build docs
diff --git a/Version.config b/Version.config
index 2e747a3..76900dd 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=2
POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=11dev
+POSTGIS_MICRO_VERSION=11
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/ci/debbie/postgis_make_dist.sh b/ci/debbie/postgis_make_dist.sh
index 0a3e8e8..5f822be 100644
--- a/ci/debbie/postgis_make_dist.sh
+++ b/ci/debbie/postgis_make_dist.sh
@@ -10,7 +10,7 @@ export OS_BUILD=64
# export POSTGIS_MICRO_VERSION=0dev
export PROJECTS=/var/lib/jenkins/workspace
export GEOS_VER=3.6
-export GDAL_VER=2.2
+export GDAL_VER=2.4
export WEB_DIR=/var/www/postgis_stuff
export PATH="${PGPATH}/bin:$PATH"
export LD_LIBRARY_PATH="${PROJECTS}/gdal/rel-${GDAL_VER}w${OS_BUILD}/lib:${PROJECTS}/geos/rel-${GEOS_VER}w${OS_BUILD}/lib:${PGPATH}/lib"
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index d2acc14..4ae8ad7 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -6,7 +6,7 @@ export OS_BUILD=64
#export reference=
export GEOS_VER=3.6
export PGPATH=${PROJECTS}/pg/rel/pg${PG_VER}w${OS_BUILD}
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index ec2026e..1711f06 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -13,7 +13,7 @@ set -e
#POSTGIS_MICRO_VERSION=0SVN
#export GCC_TYPE=gcc48 #for pre-4.8.0 compiles this is blank
export SFCGAL_VER=1.3.2
-export GEOS_VER=3.8.1
+export GEOS_VER=3.6.3
export GDAL_VER=2.4.4
export PROJ_VER=5.2.0
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 79c74e9..e8fd0d1 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -13,7 +13,7 @@
#export GCC_TYPE=
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index fd0764d..ac7d3f3 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -1,7 +1,7 @@
#!/bin/bash
set -e
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 7f0d384..0e12aa8 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -4,9 +4,10 @@
<subtitle>Release Notes</subtitle>
<sect1>
<title>Release 2.3.11</title>
- <para>Release date: 2020/05/xx</para>
+ <para>Release date: 2020/05/31</para>
<para>This is the final release for 2.3 series.
- This is a bug fix and performance improvement release.</para>
+ This is a bug fix and performance improvement release.
+ If you are running GEOS 3.7 or higher some topology tests might fail. This can be safely ignored.</para>
<simplesect>
<title>Bug Fixes and Enhancements</title>
<para>#4475, Avoid reading into empty ptarray (Paul Ramsey)</para>
Summary of changes:
Version.config | 2 +-
ci/debbie/postgis_make_dist.sh | 2 +-
ci/debbie/postgis_release_docs.sh | 2 +-
ci/winnie/build_postgis.sh | 2 +-
ci/winnie/package_postgis.sh | 2 +-
ci/winnie/regress_postgis.sh | 2 +-
doc/release_notes.xml | 5 +++--
7 files changed, 9 insertions(+), 8 deletions(-)
hooks/post-receive
