[postgis-tickets] [SCM] PostGIS branch stable-2.3 updated. 54c7108861316d7511df42016afb9b5c5c4b8605
git at osgeo.org
git at osgeo.org
Sun May 31 12:25:28 PDT 2020
the project "PostGIS".
The branch, stable-2.3 has been updated
via 54c7108861316d7511df42016afb9b5c5c4b8605 (commit)
from 24b01bda5ab45832b8a2f8902209f626dd14c602 (commit)
revisions in full, below.
commit 54c7108861316d7511df42016afb9b5c5c4b8605
Author: Regina Obe <lr at pcorp.us>
Date: Sun May 31 15:25:24 2020 -0400
Update how to release, readme, and extension to inclde dev
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index 8512d80..5980cc5 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -1,6 +1,6 @@
How to release
-Date: 2018-04-01
+Date: 2020-05-31
Versioning Scheme
@@ -57,9 +57,14 @@ documentation -- that means having the required software:
Release procedure
-- Re-generate the ChangeLog (make ChangeLog)
+- For first micro of a minor, make sure to pull the latest translations from transifex
+ TODO: more detail here - there is a job on debbie for 3.1 for examples
+ https://debbie.postgis.net/view/PostGIS/job/PostGIS_docs_translations_2.3
+ and she's setup with an api key to pull and push translations.
+- Ensure all bots are green: https://trac.osgeo.org/postgis
- Edit NEWS: set release date and check all notable changes have
- been reported (extract from ChangeLog).
+ been reported (extract from git log).
- Edit README.postgis and set release date and version.
- Add release notes in doc/release_notes.xml
- Update Version.config to drop the "dev" suffix
@@ -68,34 +73,21 @@ Release procedure
- Update the README.md to reflect new to be created buildbot badges
(this should only be needed for trunk release)
- Commit all changes
-- If this is a minor or major release (no branch exists):
- $ base=http://svn.osgeo.org/postgis/
- $ rev=x.x
- $ svn copy -m "Branch $rev" $base/trunk $base/branches/$rev
- Go to: https://debbie.postgis.net and copy last branch version and make new job
- a) Replace PostGIS_* string params with new version
- b) Replace repository url with new branch repo url
- c) Update the PostGIS_trunk by updating the PostGIS_* string params
- Go to: https://trac.osgeo.org/postgis/ edit the matrix to reflect new branch
- Tag branch: (replace x.x and x.x.x with minor and micro version e.g 2.3, 2.3.1
- $ brev=x.x
$ rev=x.x.x
- $ svn copy -m "Tagged release $rev" $base/branches/$brev $base/tags/$rev
+ $ git tag -a $rev -m "Tagged release $rev"; git push osgeo --tags
- Run: sh make_dist.sh $rev (note, debbie should have already done this,
and the file will be waiting in postgis.net/stuff. You might need to wait a few minutes to see it.)
If impatient check status of job - https://debbie.postgis.net/job/PostGIS_Make_Dist/
- Documentation should also have been built and should be in postgis.net/stuff
(this sometimes takes sometime so wait 15 minutes)
- Test generated tarball (including extension upgrade)
-- Copy tarball, pdf, doc-html.. to http://download.osgeo.org/postgis/ web site and edit postgis.net/source page
+- Copy tarball, pdf, doc-html.. to https://download.osgeo.org/postgis/ web site and edit postgis.net/source page
- Announce on e-mail
- postgis-users
- postgis-devel
- - pgsql-announce (send note to david at fetter dot org to be included in Weekly news)
+ - pgsql-announce (send email just to them, not with other ccs, they reject if others in cc)
+ - send note to david at fetter dot org to be included in Weekly news
- osgeo-discuss
- Update web sites
- PostGIS News
@@ -104,10 +96,13 @@ Release procedure
b) Update links on https://git.osgeo.org/gitea/postgis/postgis.net/src/master/_content/pages/source.html
c) commit and wait 5 minutes to see changes on website
- PostGIS doc release versioned doc - http://postgis.net/documentation/
+ - On postgis.net server, change /etc/nginx/sites-enabled/postgis.net (Versionless URL line )
+ - nginx -t #to confirm you didn't breat the config
+ - service nginx reload
Verify the documentation is up to date (might need to change the apach config)
- Wikipedia
- Twitter
- This should automatically happen as a result of posting to PostGIS website since Planet PostGIS autotweets.
+ This should automatically happen as a result of posting to PostGIS website since Planet PostGIS and Planet PostgreSQL both autotweet.
- Update Trac and make old Milestone as completed
- Push the revision number forward (see Versioning Scheme)
-- Remove the "dev" suffixed version from extensions/upgradeable_versions.mk
\ No newline at end of file
+- Remove the "dev" suffixed version from extensions/upgradeable_versions.mk
diff --git a/README.postgis b/README.postgis
index d3e89e4..05ae7bf 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 2.3.9
-:Date: 2019-03-11
+:Version: 2.3.11
+:Date: 2020-05-31
:Website: http://postgis.net
This distribution contains a module which implements GIS simple features, ties
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 960a6b1..50fb8a7 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -36,7 +36,8 @@ UPGRADEABLE_VERSIONS = \
2.3.7 \
2.3.8 \
2.3.9 \
- 2.3.10
+ 2.3.10 \
+ 2.3.11dev
# This is to avoid forcing "check-installed-upgrades" as a default
# rule, see https://trac.osgeo.org/postgis/ticket/3420
Summary of changes:
HOWTO_RELEASE | 39 +++++++++++++++++---------------------
README.postgis | 4 ++--
extensions/upgradeable_versions.mk | 3 ++-
3 files changed, 21 insertions(+), 25 deletions(-)
hooks/post-receive
