[postgis-tickets] [PostGIS] #4776: st_geometrytype causes 100% CPU loop in postgres13 on specific linestring
trac at osgeo.org
Sun Nov 1 08:41:48 PST 2020
Reporter: tvijlbrief | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.3
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by tvijlbrief):
Top 10 stack entries when hanging:
#0 pglz_decompress (source=source at entry=0x55584d6c39b0 "",
slen=<optimized out>,
dest=dest at entry=0x55584d6c3a3c "", rawsize=rawsize at entry=52,
check_complete=check_complete at entry=false) at
./build/../src/common/pg_lzcompress.c:767
#1 0x000055584c5906cb in toast_decompress_datum_slice (slicelength=52,
attr=0x55584d6c39a8)
at ./build/../src/backend/access/common/detoast.c:483
#2 detoast_attr_slice (attr=<optimized out>,
sliceoffset=sliceoffset at entry=0, slicelength=52)
at ./build/../src/backend/access/common/detoast.c:274
#3 0x000055584c9e6f2a in pg_detoast_datum_slice (datum=<optimized out>,
first=first at entry=0,
count=<optimized out>) at
./build/../src/backend/utils/fmgr/fmgr.c:1754
#4 0x00007f0bc257a7c1 in geometry_geometrytype (fcinfo=0x55584d6bea60) at
lwgeom_ogc.c:199
#5 0x000055584c740c9e in ExecInterpExpr (state=0x55584d6be578,
econtext=0x55584d6be260,
isnull=<optimized out>) at
./build/../src/backend/executor/execExprInterp.c:699
#6 0x000055584c74ec62 in ExecEvalExprSwitchContext
(isNull=0x7ffec8369497, econtext=0x55584d6be260,
state=0x55584d6be578) at
./build/../src/include/executor/executor.h:313
#7 ExecProject (projInfo=0x55584d6be570) at
./build/../src/include/executor/executor.h:347
#8 ExecScan (node=<optimized out>, accessMtd=0x55584c773130 <SeqNext>,
recheckMtd=0x55584c7731c0 <SeqRecheck>) at
./build/../src/backend/executor/execScan.c:238
#9 0x000055584c744bcd in ExecProcNode (node=0x55584d6be150)
at ./build/../src/include/executor/executor.h:245
#10 ExecutePlan (execute_once=<optimized out>, dest=0x55584d6b8640,
direction=<optimized out>,
numberTuples=0, sendTuples=<optimized out>, operation=CMD_SELECT,
use_parallel_mode=<optimized out>, planstate=0x55584d6be150,
estate=0x55584d6bded8)
at ./build/../src/backend/executor/execMain.c:1646
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4776#comment:12>
