[postgis-tickets] [PostGIS] #4781: winnie and windows failures on raster
PostGIS trac at osgeo.org
Mon Nov 2 16:27:37 PST 2020
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.1.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 I should note I'm having similar issue to winnie with failing raster
 tests.  Both of us are running GDAL 3.2.0 RC1
 Seemed to start failing after
 Commit 402fdc0e8191422b23996eafde93b2dce33c1595 by Sandro Santilli
 Run all regress tests in the same database
 Speeds up regression testing and catches some issues in presence
 of multiple components in the same db.
 Still allows running individual testsuites from within their
 respective directory.
 Last error log:
 https://winnie.postgis.net:444/job/PostGIS_EDB_Regress_winnie/11278/consoleFull
 Error looks like this:
 PostgreSQL 11.7, compiled by Visual C++ build 1914, 64-bit
   Postgis 3.1.0dev - (3.1.0alpha2-130-g812ab8609) - 2020-11-02 23:22:21
   scripts 3.1.0dev 3.1.0alpha2-130-g812ab8609
   raster scripts 3.1.0dev 3.1.0alpha2-130-g812ab8609
   GEOS: 3.9.0-CAPI-1.14.0
   PROJ: 6.3.2
   SFCGAL: 1.3.8
   GDAL: GDAL 3.2.0, released 2020/10/26
 Running tests
  ./raster/test/regress/check_gdal .. ok in 780 ms
  ./raster/test/regress/load_outdb . failed (Failed evaluating
 ./raster/test/regress/load_outdb-pre.pl: ./raster/test/regress/load_outdb:
 No such file or directory at ./raster/test/regress/load_outdb-pre.pl line
 60.)
  ./raster/test/regress/check_raster_columns .. ok in 696 ms
  ./raster/test/regress/check_raster_overviews .. ok in 567 ms
  ./raster/test/regress/rt_io .. ok in 1014 ms
  ./raster/test/regress/rt_bytea .. ok in 1201 ms
  ./raster/test/regress/rt_wkb .. failed (diff expected obtained:
 /projects/postgis/tmp/3.1.0dev_pg11_geos3.9_gdal3.2.0w64/test_198_diff)
 --- ./raster/test/regress/rt_wkb_expected       2020-11-02
 18:19:50.817116300 -0500
 +++ /projects/postgis/tmp/3.1.0dev_pg11_geos3.9_gdal3.2.0w64/test_198_out
 2020-11-02 18:51:31.349029500 -0500
 @@ -0,0 +1,13 @@
 +ERROR:  relation "raster_outdb_template" does not exist at character 103
 +ERROR:  relation "raster_outdb_template" does not exist at character 97
 +ERROR:  relation "raster_outdb_template" does not exist at character 95
 +ERROR:  relation "raster_outdb_template" does not exist at character 109
 +ERROR:  relation "raster_outdb_template" does not exist at character 100
 +ERROR:  relation "raster_outdb_template" does not exist at character 98
 +ERROR:  relation "raster_outdb_template" does not exist at character 111
 +ERROR:  relation "raster_outdb_template" does not exist at character 107
 +ERROR:  relation "raster_outdb_template" does not exist at character 67
 +ERROR:  relation "raster_outdb_template" does not exist at character 73
 +ERROR:  relation "raster_outdb_template" does not exist at character 115
  ./raster/test/regress/box3d .. ok in 328 ms
  ./raster/test/regress/rt_addband .. failed (diff expected obtained:
 /projects/postgis/tmp/3.1.0dev_pg11_geos3.9_gdal3.2.0w64/test_200_diff)
 --- ./raster/test/regress/rt_addband_expected   2020-11-02
 18:19:50.207692600 -0500
 +++ /projects/postgis/tmp/3.1.0dev_pg11_geos3.9_gdal3.2.0w64/test_200_out
 2020-11-02 18:51:33.241759100 -0500
 @@ -108,17 +108,8 @@
  5|64BF|0|f||||
  6|2BUI|0|f||||
  90
 -1|1|t|t
 -1|2|t|t
 -1|3|t|t
 -2|1|t|t
 -2|2|t|t
 -2|3|t|t
 -3|1|f|
 -3|2|t|t
 -4|1|t|t
 -4|2|f|
 -NOTICE:  Attempting to get pixel value with out of range raster
 coordinates: (99, 99)
 -255
 -90
 -255
 +ERROR:  relation "raster_outdb_template" does not exist at character 160
 +ERROR:  relation "raster_outdb_template" does not exist at character 74
  ./raster/test/regress/rt_setbandpath .. failed (diff expected obtained:
 /projects/postgis/tmp/3.1.0dev_pg11_geos3.9_gdal3.2.0w64/test_235_diff)
 --- ./raster/test/regress/rt_setbandpath_expected       2020-11-02
 18:19:50.736054500 -0500
 +++ /projects/postgis/tmp/3.1.0dev_pg11_geos3.9_gdal3.2.0w64/test_235_out
 2020-11-02 18:52:28.773544300 -0500
 @@ -1,6 +1 @@
 -1|1|t|t|1
 -1|2|t|t|2
 -1|3|t|t|3
 -2|1|t|t|2
 -2|2|t|t|2
 -2|3|t|t|3
 +ERROR:  relation "raster_outdb_template" does not exist at character 177
  ./raster/test/regress/rt_utility .. failed (diff expected obtained:
 /projects/postgis/tmp/3.1.0dev_pg11_geos3.9_gdal3.2.0w64/test_236_diff)
 --- ./raster/test/regress/rt_utility_expected   2020-11-02
 18:19:50.794653600 -0500
 +++ /projects/postgis/tmp/3.1.0dev_pg11_geos3.9_gdal3.2.0w64/test_236_out
 2020-11-02 18:52:29.732605400 -0500
 @@ -37,24 +37,8 @@
      band 3 of pixtype 16BSI is in-db with no NODATA value
  Skewed raster of 10x10 pixels has 1 band and extent of BOX(0 -10,10
 0.0001)
      band 1 of pixtype 8BUI is in-db with NODATA value of 0
 -1|Raster of 90x50 pixels has 3 bands and extent of BOX(0 -50,90 0)
 -    band 1 of pixtype 8BUI is out-db with no NODATA value
 -    band 2 of pixtype 8BUI is out-db with no NODATA value
 -    band 3 of pixtype 8BUI is out-db with no NODATA value
 -2|Raster of 90x50 pixels has 3 bands and extent of BOX(0 -50,90 0)
 -3|Raster of 90x50 pixels has 2 bands and extent of BOX(0 -50,90 0)
 -    band 1 of pixtype 8BUI is in-db with NODATA value of 0
 -4|Raster of 90x50 pixels has 2 bands and extent of BOX(0 -50,90 0)
 -    band 1 of pixtype 8BUI is out-db with NODATA value of 255
 -    band 2 of pixtype 8BUI is in-db with NODATA value of 0
 +ERROR:  relation "raster_outdb_template" does not exist at character 37
  ms1|64
  NOTICE:  Could not find raster band of index 1 when getting band path.
 Returning NULL
  bandpath1|
 -bandpath2|testraster.tif
 -bandpath2|
 +ERROR:  relation "raster_outdb_template" does not exist at character 55
  ./raster/test/regress/loader/BasicOutDB . failed (Failed evaluating
 ./raster/test/regress/loader/BasicOutDB-pre.pl:
 ./raster/test/regress/loader/BasicOutDB: No such file or directory at
 ./raster/test/regress/loader/BasicOutDB-pre.pl line 13.)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4781>
