[postgis-tickets] [PostGIS] #4785: Proj master branch (8.0.0) regress failures
PostGIS trac at osgeo.org
Fri Nov 6 04:44:33 PST 2020
  Reporter:  Taro Matsuzawa  |      Owner:  Algunenano
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.2.0
 Component:  postgis         |    Version:  master
Resolution:                  |   Keywords:
Comment (by Algunenano):
 Since this is testing that ST_Transform works after a previous failure,
 I'm planning on triggering a different proj error. Just need to check that
 the error is consistent across PROJ releases.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4785#comment:6>
