[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-155-ga55328f
git at osgeo.org
git at osgeo.org
Fri Nov 6 17:00:21 PST 2020
the project "PostGIS".
via a55328fe58bfec202f12cfa0e831dc3cf5b8e665 (commit)
from 291cb5c3006c763699f99dcf7c3647bbfc14983f (commit)
revisions in full, below.
commit a55328fe58bfec202f12cfa0e831dc3cf5b8e665
Author: Regina Obe <lr at pcorp.us>
Date: Fri Nov 6 19:59:59 2020 -0500
Change to show warning disclaimer for GEOS < 3.9
diff --git a/configure.ac b/configure.ac
index e5c9271..1bc6cca 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1689,7 +1689,7 @@ AC_MSG_RESULT([ convert: ${IMAGEMAGICK}])
AC_MSG_RESULT([ mathml2.dtd: ${MATHML2_DTD}])
AC_MSG_RESULT()
-if test "$GEOS_NUMERIC_VERSION" -lt 30800; then
+if test "$GEOS_NUMERIC_VERSION" -lt 30900; then
AC_MSG_WARN([ --------- GEOS VERSION WARNING ------------ ])
AC_MSG_WARN([ You are building against GEOS ${GEOS_FULL_VERSION}.])
AC_MSG_WARN([])
Summary of changes:
configure.ac | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
