[postgis-tickets] [PostGIS] #3372: TopoElementArray cannot be null
trac at osgeo.org
Tue Nov 17 11:40:39 PST 2020
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.0.3
Component: topology | Version: 2.0.x
Resolution: | Keywords:
Comment (by robe):
Still doesn't work on PostgreSQL 13.
Is there a reason we can't just change the constraint to:
ALTER DOMAIN topology.topoelementarray DROP CONSTRAINT dimensions;
ADD CONSTRAINT dimensions CHECK ( array_upper(VALUE, 2) = 2 AND
array_upper(VALUE, 3) IS NULL);
Then the NULL thing wouldn't violate because NULL is special. Then the
below works.
SELECT null::topoelementarray;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3372#comment:9>
