[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-164-gd2d5c9f
Wed Nov 18 14:46:58 PST 2020
the project "PostGIS".
       via  d2d5c9f98b109157e34e34e41367b82783df6be6 (commit)
      from  5829c165ccf2afcfd6d59cbe12c363f61a903c77 (commit)
revisions in full, below.
commit d2d5c9f98b109157e34e34e41367b82783df6be6
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Nov 18 17:46:41 2020 -0500
    Prep for 3.1.0alpha3 release
diff --git a/NEWS b/NEWS
index aaa227f..27d6ed9 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
 PostGIS 3.1.0alpha3
-2020/xx/xx
+2020/11/xx
 Only tickets not included in 3.1.0alpha2
 * Breaking changes *
diff --git a/README.postgis b/README.postgis
index 8379a79..5a461be 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.1.0alpha2
-:Date: 2020-07-18
+:Version: 3.1.0alpha3
+:Date: 2020-11-19
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
@@ -46,6 +46,8 @@ this to work.
     http://trac.osgeo.org/proj/
 * GEOS (Required, Version 3.6 or higher)
+  - 3.9+ is needed to take advantage of
+    fixed precision enhancements in overlay functions
   - 3.7+ is needed just for the ST_FrechetDistance function
   The GEOS library provides support for exact topological tests such as
diff --git a/Version.config b/Version.config
index e618043..26ada6e 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=1
-POSTGIS_MICRO_VERSION=0dev
+POSTGIS_MICRO_VERSION=0alpha3
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 9f5a017..3f47950 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,10 +2,74 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+    <sect1><title>Release 3.1.0alpha3</title>
+        <para>Release date: 2020/11/19</para>
+        <para>Only changes since 3.1.0alpah2 are listed. This version requires PostgreSQL 9.6-13 and GEOS >= 3.6+
+                Additional features and enhancements enabled if you are running Proj6+, PostgreSQL 12+, and GEOS 3.9.0dev</para>
+        <simplesect><title>Breaking changes</title>
+            <para>4737, Bump minimum protobuf-c requirement to 1.1.0 (Raúl Marín)
+                    The configure step will now fail if the requirement isn't
+                    met or explicitly disabled (--without-protobuf)</para>
+            <para>4258, Untangle postgis_sfcgal from postgis
+                    into its own lib file (Regina Obe)</para>
+        </simplesect>
+        <simplesect><title>New features</title>
+            <para>4698, Add a precision parameter to ST_AsEWKT (Raúl Marín)</para>
+            <para>Add a gridSize optional parameter to ST_Union, ST_UnaryUnion,
+                ST_Difference, ST_Intersection, ST_SymDifference, ST_Subdivide
+                Requires GEOS 3.9 (Sandro Santilli)</para>
+        </simplesect>
+        <simplesect><title>Enhancements</title>
+            <para>4789, Speed up TopoJSON output for areal TopoGeometry with
+                    many holes (Sandro Santilli)</para>
+            <para>4758, Improve topology noding robustness (Sandro Santilli)</para>
+            <para>Make ST_Subdivide interruptable (Sandro Santilli)</para>
+            <para>4660, Changes in double / coordinate printing (Raúl Marín)
+                - Use the shortest representation (enough to guarantee roundtrip).
+                - Uses scientific notation for absolute numbers smaller than 1e-8.
+                The previous behaviour was to output 0 for absolute values smaller than
+                1e-12 and fixed notation for anything bigger than that.
+                - Uses scientific notation for absolute numbers greater than 1e+15 (same behaviour).
+                - The precision parameter now also affects the scientific notation (before it was fixed [5-8]).
+                - All output functions now respect the requested precision (without any limits).
+                - The default precision is the same (9 for GeoJSON, 15 for everything else).</para>
+            <para>4729, WKT/KML: Print doubles directly into stringbuffers (Raúl Marín)</para>
+            <para>4533, Use the standard coordinate printing system for box types (Raúl Marín)</para>
+            <para>4686, Avoid decompressing geographies when possible (Raúl Marín)
+                Affects ANALYZE, _ST_PointOutside, postgis_geobbox, ST_CombineBbox(box2d, geometry),
+                ST_ClipByBox2D when the geometry is fully inside or outside the bbox and
+                ST_BoundingDiagonal.</para>
+            <para>4741, Don't use ST_PointInsideCircle if you need indexes, use ST_DWithin instead.
+                    Documentation adjusted (Darafei Praliaskouski)</para>
+            <para>4737, Improve performance and reduce memory usage in ST_AsMVT, especially in
+                    queries involving parallelism (Raúl Marín)</para>
+            <para>4746, Micro optimizations to the serialization process (Raúl Marín)</para>
+            <para>4719, Fail fast when srids don't match ST_Intersection(geometry,raster)
+            Also schema qualify calls in function. (Regina Obe)</para>
+            <para>4784, Add ST_CollectionExtract(geometry) with default behaviour of
+           extracting the components of highest coordinate dimension. (Paul Ramsey)</para>
+        </simplesect>
+        <simplesect><title>Bug Fixes</title>
+            <para>4691, Fix segfault during gist index creation with empty geometries (Raúl Marín)</para>
+            <para>Fix handling of bad WKB inputs (Oracle types) and unit tests for
+                malformed WKB. Remove memory leaks in malformed WKB cases. (Paul Ramsey)</para>
+            <para>4740, Round values in geography_distance_tree
+                    as we do on geography_distance (Raúl Marín, Paul Ramsey, Regina Obe)</para>
+            <para>4739, Ensure all functions using postgis_oid initialize the internal cache (Raúl Marín)</para>
+            <para>4767, #4768, #4771, #4772, Fix segfault when parsing invalid WKB (Raúl Marín)</para>
+            <para>4769, Fix segfault in st_addband (Raúl Marín)</para>
+            <para>4790, Fix ST_3dintersects calculations with identical vertices (Nicklas Avén)</para>
+            <para>4742, tiger geocoder reverted to 2018 version on tiger upgrade (Regina Obe)</para>
+            <para>3372, TopoElementArray cannot be null - change domain constraint (Regina Obe)</para>
+        </simplesect>
+    </sect1>
     <sect1>
         <title>Release 3.1.0alpha2</title>
         <para>Release date: 2020/07/18</para>
-        <para>Only changes since 3.1.0alpah1 and listed. This version requires PostgreSQL 9.6-13 and GEOS >= 3.6+
+        <para>Only changes since 3.1.0alpah1 are listed. This version requires PostgreSQL 9.6-13 and GEOS >= 3.6+
         <simplesect>
             <title>New Features</title>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 4c7aeb7..9e25ec5 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -53,14 +53,9 @@ UPGRADEABLE_VERSIONS = \
 	2.5.2 \
 	2.5.3 \
 	2.5.4 \
-	3.0.0alpha1 \
-	3.0.0alpha2 \
-	3.0.0alpha3 \
-	3.0.0alpha4 \
-	3.0.0beta1 \
-	3.0.0rc1 \
-	3.0.0rc2 \
 	3.0.0 \
 	3.0.1 \
+	3.0.2 \
+	3.0.3 \
 	3.1.0alpha1 \
 	3.1.0alpha2
Summary of changes:
 NEWS                               |  2 +-
 README.postgis                     |  6 ++--
 Version.config                     |  2 +-
 doc/release_notes.xml              | 66 +++++++++++++++++++++++++++++++++++++-
 extensions/upgradeable_versions.mk |  9 ++----
 5 files changed, 73 insertions(+), 12 deletions(-)
hooks/post-receive
