[postgis-tickets] [PostGIS] #4797: Slow down on ST_DWithin upgrading from PostGis 2.5 to PostGis 3.0
trac at osgeo.org
Fri Nov 20 08:55:18 PST 2020
Reporter: aelg | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Keywords: |
Hello,
We're using PostGis in production, currently Postgres9.6/PostGis 2.5 and
wanted to upgrade to Postgres12/PostGis 3.0.
But doing so we noticed a major slow down on requests which implies
ST_DWithin, sometimes 1 sec on PG2.5 to 100sec on PG3.0.
I can confirm now that it's not related to upgrading Postgres because I
can reproduce slow requests with docker image
postgis/postgis:12-3.0-alpine, but requests are fast on
postgis/postgis:12-2.5-alpine.
Query is:
SELECT "profile"."user_id" AS "profile_user_id" FROM "algorithmUser"
"profile" LEFT JOIN "algorithmInteraction" "interaction" ON
"interaction"."female_user_id"="profile"."user_id" AND
("interaction"."male_user_id" = '*AN_ID*') WHERE "profile"."gender" =
'FEMALE' AND "profile"."is_qualified_to_be_suggested" = true AND
"profile"."birthdate" BETWEEN '1981-11-04' AND '2006-11-04' AND
"profile"."last_activity_date" >'now'::timestamp - '2 month'::interval AND
ST_DWithin(
ST_SetSRID(profile.location::geometry, 4326)::geography,
ST_SetSRID(ST_MakePoint('2.346120595932007', '48.87633514404297'),
4326)::geography,
'150000'
) AND ("interaction"."male_user_id" is NULL OR
"interaction"."male_interaction_result" = 'NOT_INTERACTED') ORDER BY
"profile"."last_activity_date" DESC LIMIT 30;
Here is a fast plane on PostGis2.5:
Limit (cost=32985.40..32985.41 rows=7 width=24) (actual
time=1309.848..1310.630 rows=30 loops=1)
-> Sort (cost=32985.40..32985.41 rows=7 width=24) (actual
time=1309.830..1310.193 rows=30 loops=1)
Sort Key: profile.last_activity_date DESC
Sort Method: top-N heapsort Memory: 29kB
-> Nested Loop Left Join (cost=1000.00..32985.30 rows=7
width=24) (actual time=88.130..1304.894 rows=669 loops=1)
Join Filter: (interaction.female_user_id = profile.user_id)
Rows Removed by Join Filter: 88289
Filter: ((interaction.male_user_id IS NULL) OR
(interaction.male_interaction_result =
'NOT_INTERACTED'::"algorithmInteraction_male_interaction_result_enum"))
Rows Removed by Filter: 93
-> Seq Scan on "algorithmUser" profile
(cost=0.00..6778.62 rows=34 width=24) (actual time=0.299..15.348 rows=762
loops=1)
Filter: (is_qualified_to_be_suggested AND (birthdate
>= '1981-11-04'::date) AND (birthdate <= '2006-11-04'::date) AND
(last_activity_date > '2020-09-19 17:41:18.3546'::timestamp without time
zone) AND (gender = 'FEMALE'::"algorithmUser_gender_enum") AND
((st_setsrid((location)::geometry, 4326))::geography &&
'0101000020E6100000000000E0DAC40240000000C02B704840'::geography) AND
('0101000020E6100000000000E0DAC40240000000C02B704840'::geography &&
_st_expand((st_setsrid((location)::geometry, 4326))::geography,
'150000'::double precision)) AND
_st_dwithin((st_setsrid((location)::geometry, 4326))::geography,
'0101000020E6100000000000E0DAC40240000000C02B704840'::geography,
'150000'::double precision, true))
Rows Removed by Filter: 14830
-> Materialize (cost=1000.00..26139.72 rows=113 width=36)
(actual time=0.105..0.885 rows=116 loops=762)
-> Gather (cost=1000.00..26139.16 rows=113
width=36) (actual time=75.378..85.228 rows=116 loops=1)
Workers Planned: 2
Workers Launched: 2
-> Parallel Seq Scan on "algorithmInteraction"
interaction (cost=0.00..25127.86 rows=47 width=36) (actual
time=59.813..70.948 rows=39 loops=3)
Filter: (male_user_id = '15fe5c41-d2a8
-431e-ad4b-93134d301ecd'::uuid)
Rows Removed by Filter: 326928
Planning Time: 0.609 ms
Execution Time: 1310.916 ms
And a slow one Postgis 3.0:
Limit (cost=444330.70..444330.71 rows=1 width=24) (actual
time=102934.658..102938.991 rows=30 loops=1)
-> Sort (cost=444330.70..444330.71 rows=1 width=24) (actual
time=102917.048..102921.012 rows=30 loops=1)
-> Nested Loop Left Join (cost=1000.00..444330.69 rows=1
width=24) (actual time=501.099..102912.441 rows=669 loops=1)
(cost=0.00..420185.68 rows=1 width=24) (actual time=12.700..55.290
rows=762 loops=1)
(last_activity_date > '2020-09-19 17:43:53.189431'::timestamp without time
-> Gather (cost=1000.00..24104.47 rows=2703 width=36)
(actual time=115.965..133.717 rows=116 loops=762)
Workers Planned: 2
Workers Launched: 2
interaction (cost=0.00..22834.17 rows=1126 width=36) (actual
time=55.030..67.398 rows=39 loops=2286)
Filter: (male_user_id = '15fe5c41-d2a8-431e-
Planning Time: 0.124 ms
JIT:
Functions: 20
Options: Inlining false, Optimization false, Expressions true,
Deforming true
Timing: Generation 11.106 ms, Inlining 0.000 ms, Optimization 1.923 ms,
Emission 38.001 ms, Total 51.030 ms
Execution Time: 103113.558 ms
Would you see a work around we could use?
Thanks,
Aël
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4797>
