[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-2-g7ab0110
Fri Nov 20 17:02:00 PST 2020
the project "PostGIS".
       via  7ab01105ef45f2319c361174a27c6e7900069d32 (commit)
      from  7d5dd6338cae8633acf4b202b7872130fa614132 (commit)
revisions in full, below.
commit 7ab01105ef45f2319c361174a27c6e7900069d32
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Nov 20 20:01:49 2020 -0500
    Put a note in Enhanced when requires GEOS 3.9.0, change sorting so new changes come at top
diff --git a/doc/reference_constructor.xml b/doc/reference_constructor.xml
index 4d18ea7..176a3ac 100644
--- a/doc/reference_constructor.xml
+++ b/doc/reference_constructor.xml
@@ -850,7 +850,7 @@ SELECT ST_AsText( ST_TileEnvelope(3, 1, 1, ST_MakeEnvelope(-180, -90, 180, 90, 4
 				<imagedata fileref='images/st_hexagongrid02.png' />
 			</imageobject></inlinemediaobject></para>
-			<para>Availability: 3.1</para>
+			<para>Availability: 3.1.0</para>
 		</refsection>
@@ -927,7 +927,7 @@ WHERE
             perfectly fits with the original tiling. Standard web map tilings in mercator
             are just powers-of-two square grids in the mercator plane.</para>
         </refsection>
@@ -997,7 +997,7 @@ WHERE
 			</para>
 			<para>Hexagons are generated with no SRID set, so use <xref linkend="ST_SetSRID" /> to set the SRID to the one you expect.</para>
 		</refsection>
 		<refsection>
@@ -1044,7 +1044,7 @@ POLYGON((-1 0,-0.5
 			</para>
 			<para>Squares are generated with no SRID set, so use <xref linkend="ST_SetSRID" /> to set the SRID to the one you expect.</para>
 		</refsection>
 		<refsection>
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index b2dd96f..c40b075 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -56,8 +56,9 @@
 			<note>
 			  <para>ST_AsEWKT is the reverse of <xref linkend="ST_GeomFromEWKT" />.  Use <xref linkend="ST_GeomFromEWKT" /> to convert to a postgis geometry from ST_AsEWKT representation.</para>
 			</note>
-			<para>Enhanced: 2.0.0 support for Geography, Polyhedral surfaces, Triangles and TIN was introduced.</para>
             <para>Enhanced: 3.1.0 support for optional precision parameter.</para>
+			<para>Enhanced: 2.0.0 support for Geography, Polyhedral surfaces, Triangles and TIN was introduced.</para>
 			<para>&Z_support;</para>
 			<para>&curve_support;</para>
 			<para>&P_support;</para>
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 1a4171a..dbd34e7 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1253,8 +1253,7 @@ on that same grid. This method requires GEOS-3.9.0 or higher.
             </para>
         <para>Performed by the GEOS module</para>
-        <para>Enhanced: 3.1.0 accept a gridSize parameter.</para>
+        <para>Enhanced: 3.1.0 accept a gridSize parameter - requires GEOS >= 3.9.0</para>
         <para>&sfs_compliant; s2.1.1.3</para>
         <para>&sqlmm_compliant; SQL-MM 3: 5.1.20</para>
@@ -1662,14 +1661,14 @@ on that same grid. This method requires GEOS-3.9.0 or higher.
           <warning><para>If working with 3D geometries, you may want to use SFGCAL based <xref linkend="ST_3DIntersection" /> which does a proper 3D intersection for 3D geometries.  Although this function works with Z-coordinate, it does an averaging of Z-Coordinate.</para></warning>
-          <para>Performed by the GEOS module</para>
+            <para>Performed by the GEOS module</para>
-          <para>Availability: 1.5 support for geography data type was introduced.</para>
             <para>Changed: 3.0.0 does not depend on SFCGAL.</para>
-            <para>Changed: 3.1.0 added gridSize argument.</para>
+            <para>Availability: 1.5 support for geography data type was introduced.</para>
-          <para>&sfs_compliant; s2.1.1.3</para>
-          <para>&sqlmm_compliant; SQL-MM 3: 5.1.18</para>
+            <para>&sfs_compliant; s2.1.1.3</para>
+            <para>&sqlmm_compliant; SQL-MM 3: 5.1.18</para>
         </refsection>
         <refsection>
         <title>Examples</title>
@@ -3461,7 +3460,7 @@ on that same grid. This method requires GEOS-3.9.0 or higher.
         <para>&sqlmm_compliant; SQL-MM 3: 5.1.21</para>
@@ -3717,9 +3716,10 @@ LINESTRING(44.7994523421035 82.5156766227011,85 85)</screen>
     <para>NOTE: this function was formerly called GeomUnion(), which
         was renamed from "Union" because UNION is an SQL reserved
         word.</para>
-    <para>Availability: 1.4.0 - ST_Union was enhanced. ST_Union(geomarray) was introduced and also faster aggregate collection in PostgreSQL.</para>
+    <para>Availability: 1.4.0 - ST_Union was enhanced. ST_Union(geomarray) was introduced and also faster aggregate collection in PostgreSQL.</para>
     <note><para>Aggregate version is not explicitly defined in OGC SPEC.</para></note>
@@ -3850,9 +3850,9 @@ on that same grid. This method requires GEOS-3.9.0 or higher.
         </para>
         <para>Availability: 2.0.0</para>
       </refsection>
Summary of changes:
 doc/reference_constructor.xml |  8 ++++----
 doc/reference_output.xml      |  3 ++-
 doc/reference_processing.xml  | 24 ++++++++++++------------
 3 files changed, 18 insertions(+), 17 deletions(-)
hooks/post-receive
