[postgis-tickets] [PostGIS] #4799: ST_AsGeoJSON doesn't export the CRS of multiple geometry columns
PostGIS trac at osgeo.org
Fri Nov 20 18:18:03 PST 2020
 Reporter:  tobwen                |      Owner:  pramsey
     Type:  enhancement           |     Status:  new
 Priority:  medium                |  Milestone:  PostGIS 3.1.0
Component:  postgis               |    Version:  master
 Keywords:  geojson, json, jsonb  |
 == summary
 ST_AsGeoJSON only uses the first geometry column to create the feature's
 geometry. The other geometry columns get stored in properties. But here,
 the CRS is missing. It's not in GeoJSON specs, but it might be useful to
 reconstruct the geometry.
 == example
 SELECT
     ST_AsGeoJSON(data.*)
 FROM
     (SELECT
         1 AS id,
         ST_Transform(geom, 3035) geom,
         ST_Transform(geom, 25832) geom
     FROM
         ST_SetSRID(ST_MakePoint(7, 51), 4326) geom
     ) data;
 == result
   "type":"Feature",
   "geometry":{
     "type":"Point",
     "crs":{
       "type":"name",
       "properties":{
         "name":"EPSG:3035"
     "coordinates":[
       4110471.051819585,
       3103060.820290524
   "properties":{
     "id":1,
     "geom":{
       "type":"Point",
       "coordinates":[
         359666.70366028673,
         5651728.682548149
 == nice to have
   "type":"Feature",
   "geometry":{
     "type":"Point",
     "crs":{
       "type":"name",
       "properties":{
         "name":"EPSG:3035"
     "coordinates":[
       4110471.051819585,
       3103060.820290524
   "properties":{
     "id":1,
     "geom":{
       "crs":{
         "type":"name",
         "properties":{
           "name":"EPSG:25832"
       "type":"Point",
       "coordinates":[
         359666.70366028673,
         5651728.682548149
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4799>
