[postgis-tickets] [PostGIS] #4802: Spatial query with find_srid() not using the spatial index
trac at osgeo.org
Tue Nov 24 04:13:24 PST 2020
Reporter: Paco Calvo | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Keywords: |
After posting a message on postgis-users about this, I'd been advised to
open a ticket here. That message follows.
I'm having an issue with the planner using a sequential scan instead of
the spatial index over a big table with several millions of geometries. My
query is similar to this, where the query parameters are the coordinates
for a point:
select * from my_table
where st_contains(geometry, st_setsrid(st_point(x, y), find_srid('public',
'my_table', 'geometry')))
This occurs with PostGIS 3.0 ('POSTGIS="3.0.3 3.0.3" [EXTENSION]
PGSQL="110" GEOS="3.8.1-CAPI-1.13.3" PROJ="7.1.1" LIBXML="2.9.9"
LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.4.3 (Internal)"') on Potgres
11 and 9.6, both for Windows and fully patched. Works as expected on other
instances with Postgres 10 and 12 and PostGIS 2.5.3 and 3.0.3,
respectively.
Using other predicates as st_intersection instead of st_contains or
reindexing and analyzing the table doesn't work. Changing find_srid(...)
for a constant value uses the expected plan. As a workaround, I've
extracted the construction of the second geometry (st_setsrid(...)) to a
CTE, giving a plan similar to the expected one.
Thanks in advance,
Paco Calvo
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4802>
