[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-9-g8b13c3e
Sat Nov 28 14:40:41 PST 2020
the project "PostGIS".
       via  8b13c3e2f8366d902dbf516ec17de09ae84361f4 (commit)
      from  87812cbd6d1e1348de83b82ee3980f6ef19083a1 (commit)
revisions in full, below.
commit 8b13c3e2f8366d902dbf516ec17de09ae84361f4
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Nov 29 01:40:15 2020 +0300
    Expose _ST_SortableHash
    Intentionally undocumented. Use as a work around for slow
    ORDER BY geom in parallel plans until Postgres gets better.
    Closes #4805
diff --git a/NEWS b/NEWS
index 866b944..165f568 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,9 @@ Only tickets not included in 3.1.0alpha3
  * New features*
   - #4801, ST_ClusterKMeans supports weights in POINT[Z]M geometries (Darafei Praliaskouski)
   - #4804, ST_ReducePrecision (GEOS 3.9+) allows valid precision reduction (Paul Ramsey)
+  - #4805, _ST_SortableHash exposed to work around parallel soring performance issue
+           in Postgres. If your table is huge, use ORDER BY _ST_SortableHash(geom)
+           instead of ORDER BY geom to make parallel sort faster (Darafei Praliaskouski)
 PostGIS 3.1.0alpha3
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index c5b9e30..20c9aed 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -2710,6 +2710,14 @@ Datum ST_GeoHash(PG_FUNCTION_ARGS)
 	PG_RETURN_NULL();
+PG_FUNCTION_INFO_V1(_ST_SortableHash);
+Datum _ST_SortableHash(PG_FUNCTION_ARGS)
+	if (PG_ARGISNULL(0))
+		PG_RETURN_NULL();
+	PG_RETURN_INT64(gserialized_get_sortable_hash(PG_GETARG_GSERIALIZED_P(0)));
 PG_FUNCTION_INFO_V1(ST_CollectionExtract);
 Datum ST_CollectionExtract(PG_FUNCTION_ARGS)
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 5310d48..9e49473 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4973,6 +4973,14 @@ CREATE OR REPLACE FUNCTION ST_GeoHash(geom geometry, maxchars int4 DEFAULT 0)
 	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
 	_COST_LOW;
+-- Availability 3.1.0
+CREATE OR REPLACE FUNCTION _ST_SortableHash(geom geometry)
+	RETURNS bigint
+	AS 'MODULE_PATHNAME', '_ST_SortableHash'
+	LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE
+	_COST_LOW;
 -- GeoHash input
 -- Availability: 2.0.?
diff --git a/regress/core/regress_index.sql b/regress/core/regress_index.sql
index df7768a..d3dd0e5 100644
--- a/regress/core/regress_index.sql
+++ b/regress/core/regress_index.sql
@@ -111,3 +111,6 @@ DROP FUNCTION qnodes(text);
 set enable_indexscan = on;
 set enable_bitmapscan = on;
 set enable_seqscan = on;
+-- _ST_SortableHash is a work around Postgres parallel sort requiring recalculation of abbreviated keys.
+select '_st_sortablehash', _ST_SortableHash('POINT(0 0)'), _ST_SortableHash('SRID=4326;POINT(0 0)'), _ST_SortableHash('SRID=3857;POINT(0 0)');
diff --git a/regress/core/regress_index_expected b/regress/core/regress_index_expected
index ae75d05..657981f 100644
--- a/regress/core/regress_index_expected
+++ b/regress/core/regress_index_expected
@@ -14,3 +14,4 @@ expr|3+=5:true
 expr|924+=60:true
 expr|12621+=500:true
 expr|50000+=600:true
+_st_sortablehash|0|768602608280535040|768602608280535040
Summary of changes:
 NEWS                                | 3 +++
 postgis/lwgeom_functions_basic.c    | 8 ++++++++
 postgis/postgis.sql.in              | 8 ++++++++
 regress/core/regress_index.sql      | 3 +++
 regress/core/regress_index_expected | 1 +
 5 files changed, 23 insertions(+)
hooks/post-receive
