[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha3-15-ged1de58
git at osgeo.org
git at osgeo.org
Sat Nov 28 19:01:20 PST 2020
the project "PostGIS".
via ed1de589b145cf1b02f68c2a04b6d211f0c62889 (commit)
from d159dcf8d70b5c0b733c248bef44a66b6da51333 (commit)
revisions in full, below.
commit ed1de589b145cf1b02f68c2a04b6d211f0c62889
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Nov 29 06:01:00 2020 +0300
Generate Correlation statistics so BRIN works.
Closes #4625
diff --git a/NEWS b/NEWS
index ee001fc..407815b 100644
--- a/NEWS
+++ b/NEWS
@@ -15,7 +15,9 @@ Only tickets not included in 3.1.0alpha3
- #4805, _ST_SortableHash exposed to work around parallel soring performance issue
in Postgres. If your table is huge, use ORDER BY _ST_SortableHash(geom)
instead of ORDER BY geom to make parallel sort faster (Darafei Praliaskouski)
+ - #4625, Correlation statistics now calculated.
+ Run ANALYZE for BRIN indexes to start kicking in.
+ (Darafei Praliaskouski)
PostGIS 3.1.0alpha3
2020/11/19
diff --git a/postgis/gserialized_estimate.c b/postgis/gserialized_estimate.c
index b5202d7..71a29a9 100644
--- a/postgis/gserialized_estimate.c
+++ b/postgis/gserialized_estimate.c
@@ -168,8 +168,17 @@ Datum geometry_estimated_extent(PG_FUNCTION_ARGS);
#define STATISTIC_KIND_ND 102
#define STATISTIC_KIND_2D 103
-#define STATISTIC_SLOT_ND 0
-#define STATISTIC_SLOT_2D 1
+ * Postgres does not pin its slots and uses them as they come.
+ * We need to preserve its Correlation for brin to work
+ * 0 may be MCV
+ * 1 may be Histogram
+ * 2 may be Correlation
+ * We take 3 and 4.
+#define STATISTIC_SLOT_ND 3
+#define STATISTIC_SLOT_2D 4
* The SD factor restricts the side of the statistics histogram
@@ -274,8 +283,11 @@ typedef struct ND_STATS_T
float4 value[1];
} ND_STATS;
+typedef struct {
+ /* Saved state from std_typanalyze() */
+ AnalyzeAttrComputeStatsFunc std_compute_stats;
+ void *std_extra_data;
+} GserializedAnalyzeExtraData;
* Given that geodetic boxes are X/Y/Z regardless of the
@@ -1345,9 +1357,6 @@ Datum gserialized_gist_joinsel(PG_FUNCTION_ARGS)
PG_RETURN_FLOAT8(gserialized_joinsel_internal(root, args, jointype, mode));
* The gserialized_analyze_nd sets this function as a
* callback on the stats object when called by the ANALYZE
@@ -1363,7 +1372,7 @@ Datum gserialized_gist_joinsel(PG_FUNCTION_ARGS)
* for use by operator estimators.
* We will populate an n-d histogram using the provided
- * sample rows. The selectivity estimators (sel and j_oinsel)
+ * sample rows. The selectivity estimators (sel and joinsel)
* can then use the histogram
static void
@@ -1864,6 +1873,12 @@ static void
compute_gserialized_stats(VacAttrStats *stats, AnalyzeAttrFetchFunc fetchfunc,
int sample_rows, double total_rows)
+ GserializedAnalyzeExtraData *extra_data = (GserializedAnalyzeExtraData *)stats->extra_data;
+ /* Call standard statistics calculation routine to fill in correlation for BRIN to work */
+ stats->extra_data = extra_data->std_extra_data;
+ extra_data->std_compute_stats(stats, fetchfunc, sample_rows, total_rows);
+ stats->extra_data = extra_data;
/* 2D Mode */
compute_gserialized_stats_mode(stats, fetchfunc, sample_rows, total_rows, 2);
@@ -1900,30 +1915,24 @@ compute_gserialized_stats(VacAttrStats *stats, AnalyzeAttrFetchFunc fetchfunc,
* Being this experimental we'll stick to a static stat_builder/sample_rows
* value for now.
PG_FUNCTION_INFO_V1(gserialized_analyze_nd);
Datum gserialized_analyze_nd(PG_FUNCTION_ARGS)
VacAttrStats *stats = (VacAttrStats *)PG_GETARG_POINTER(0);
- Form_pg_attribute attr = stats->attr;
+ (GserializedAnalyzeExtraData *)palloc(sizeof(GserializedAnalyzeExtraData));
- POSTGIS_DEBUG(2, "gserialized_analyze_nd called");
+ /* Ask for standard analyze to fill in as much as possible */
+ if (!std_typanalyze(stats))
+ PG_RETURN_BOOL(false);
- /* If the attstattarget column is negative, use the default value */
- /* NB: it is okay to scribble on stats->attr since it's a copy */
- if (attr->attstattarget < 0)
- attr->attstattarget = default_statistics_target;
- POSTGIS_DEBUGF(3, " attribute stat target: %d", attr->attstattarget);
- /* Setup the minimum rows and the algorithm function.
- * 300 matches the default value set in
- * postgresql/src/backend/commands/analyze.c */
- stats->minrows = 300 * stats->attr->attstattarget;
+ /* Save old compute_stats and extra_data for scalar statistics ... */
+ extra_data->std_compute_stats = stats->compute_stats;
+ extra_data->std_extra_data = stats->extra_data;
+ /* ... and replace with our info */
stats->compute_stats = compute_gserialized_stats;
- POSTGIS_DEBUGF(3, " minrows: %d", stats->minrows);
/* Indicate we are done successfully */
PG_RETURN_BOOL(true);
@@ -2462,7 +2471,7 @@ table_get_spatial_index(Oid tbl_oid, text *col, int *key_type)
/* Save result, clean up, and break out */
result = idx_oid;
if (key_type)
- *key_type = (atttypid == b2d_oid ? STATISTIC_SLOT_2D : STATISTIC_SLOT_ND);
+ *key_type = (atttypid == b2d_oid ? STATISTIC_KIND_2D : STATISTIC_KIND_ND);
break;
@@ -2507,7 +2516,7 @@ spatial_index_read_extent(Oid idx_oid, int key_type)
Datum idx_attr = index_getattr(ituple, 1, idx_rel->rd_att, &isnull);
if (!isnull)
- if (key_type == STATISTIC_SLOT_2D)
+ if (key_type == STATISTIC_KIND_2D)
BOX2DF *b = (BOX2DF*)DatumGetPointer(idx_attr);
if (bounds_2df)
@@ -2531,14 +2540,14 @@ spatial_index_read_extent(Oid idx_oid, int key_type)
ReleaseBuffer(buffer);
index_close(idx_rel, AccessShareLock);
- if (key_type == STATISTIC_SLOT_2D && bounds_2df)
+ if (key_type == STATISTIC_KIND_2D && bounds_2df)
if (box2df_is_empty(bounds_2df))
return NULL;
gbox = gbox_new(0);
box2df_to_gbox_p(bounds_2df, gbox);
- else if (key_type == STATISTIC_SLOT_ND && bounds_gidx)
+ else if (key_type == STATISTIC_KIND_ND && bounds_gidx)
if (gidx_is_unknown(bounds_gidx))
return NULL;
diff --git a/raster/rt_pg/rtpostgis_drop.sql.in b/raster/rt_pg/rtpostgis_drop.sql.in
index d63c365..259692c 100644
--- a/raster/rt_pg/rtpostgis_drop.sql.in
+++ b/raster/rt_pg/rtpostgis_drop.sql.in
@@ -111,7 +111,7 @@ DROP FUNCTION IF EXISTS st_quantile(rastertable text, rastercolumn text, nband i
DROP FUNCTION IF EXISTS st_quantile(rastertable text, rastercolumn text, nband int, quantile double precision);
DROP FUNCTION IF EXISTS st_quantile(rastertable text, rastercolumn text, exclude_nodata_value boolean, quantile double precision);
DROP FUNCTION IF EXISTS st_quantile(rastertable text, rastercolumn text, quantile double precision);
-DROP FUNCTION IF EXISTS st_approxquantile(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, sample_percent double precision DEFAULT 0.1, quantiles double precision[], OUT quantile double precision, OUT value double precision);
+DROP FUNCTION IF EXISTS st_approxquantile(rastertable text, rastercolumn text, nband int, exclude_nodata_value boolean, sample_percent double precision, quantiles double precision[], OUT quantile double precision, OUT value double precision);
DROP FUNCTION IF EXISTS st_approxquantile( rastertable text, rastercolumn text, nband int, sample_percent double precision, quantiles double precision[], OUT quantile double precision, OUT value double precision);
DROP FUNCTION IF EXISTS st_approxquantile( rastertable text, rastercolumn text, sample_percent double precision, quantiles double precision[], OUT quantile double precision, OUT value double precision);
DROP FUNCTION IF EXISTS st_approxquantile( rastertable text, rastercolumn text, quantiles double precision[], OUT quantile double precision, OUT value double precision);
diff --git a/regress/core/regress_selectivity_expected b/regress/core/regress_selectivity_expected
index a399aed..5a12f04 100644
--- a/regress/core/regress_selectivity_expected
+++ b/regress/core/regress_selectivity_expected
@@ -2,7 +2,7 @@ ERROR: stats for "no_stats.g" do not exist
ERROR: stats for "no_stats_join.g" do not exist
-public|regular_overdots|g|f|0|32|-1|||||||
+public|regular_overdots|g|f|0|32|-1|{0101000000000000000000F03F000000000000F03F:010100000000000000000000400000000000000040:010100000000000000000008400000000000000840:0101000000000000000000F03F0000000000000840:01010000000000000000000840000000000000F03F:0101000000000000000000F03F0000000000000040:01010000000000000000000040000000000000F03F:010100000000000000000010400000000000001040:0101000000000000000000F03F0000000000001440:010100000000000000000000400000000000001040:010100000000000000000010400000000000000040:01010000000000000000001440000000000000F03F:0101000000000000000000F03F0000000000001040:01010000000000000000001040000000000000F03F:010100000000000000000008400000000000000040:010100000000000000000000400000000000000840:010100000000000000000014400000000000001440:010100000000000000000000400000000000001840:010100000000000000000008400000000000001440:010100000000000000000014400000000000000840:010100000000000000000018400000000000000040:0101000000000000000000F03F0000000000001C40:01010000000000
0000000000400000000000001440:010100000000000000000014400000000000000040:01010000000000000000001C40000000000000F03F:010100000000000000000008400000000000001040:010100000000000000000010400000000000000840:0101000000000000000000F03F0000000000001840:01010000000000000000001840000000000000F03F:010100000000000000000010400000000000001840:010100000000000000000018400000000000001040:010100000000000000000008400000000000001840:010100000000000000000008400000000000001C40:010100000000000000000018400000000000001840:01010000000000000000001C400000000000000840:010100000000000000000018400000000000000840:010100000000000000000014400000000000001040:010100000000000000000010400000000000001440:010100000000000000000000400000000000001C40:01010000000000000000001C400000000000000040:010100000000000000000020400000000000000040:010100000000000000000000400000000000002040:010100000000000000000014400000000000001C40:01010000000000000000001C400000000000001440:010100000000000000000010400000000000001C40:0101000000000000000000
1C400000000000001040:0101000000000000000000F03F0000000000002040:010100000000000000000014400000000000001840:01010000000000000000001C400000000000001C40:010100000000000000000018400000000000001440:010100000000000000000020400000000000001040:010100000000000000000010400000000000002040:01010000000000000000002040000000000000F03F:0101000000000000000000F03F0000000000002240:01010000000000000000002240000000000000F03F:010100000000000000000020400000000000000840:010100000000000000000022400000000000000840:010100000000000000000008400000000000002040:010100000000000000000008400000000000002240:010100000000000000000018400000000000001C40:01010000000000000000001C400000000000001840:010100000000000000000020400000000000001840:010100000000000000000018400000000000002040:010100000000000000000020400000000000001440:010100000000000000000014400000000000002040:010100000000000000000022400000000000000040:010100000000000000000020400000000000002040:010100000000000000000000400000000000002240:010100000000000000000022400000
000000001040:010100000000000000000022400000000000001440:010100000000000000000014400000000000002240:010100000000000000000010400000000000002240:010100000000000000000024400000000000000040:010100000000000000000020400000000000001C40:01010000000000000000001C400000000000002040:010100000000000000000000400000000000002440:010100000000000000000022400000000000001840:010100000000000000000022400000000000001C40:01010000000000000000001C400000000000002240:010100000000000000000018400000000000002240:010100000000000000000024400000000000001040:010100000000000000000010400000000000002440:0101000000000000000000F03F0000000000002440:010100000000000000000024400000000000001840:010100000000000000000022400000000000002240:010100000000000000000018400000000000002440:01010000000000000000002440000000000000F03F:010100000000000000000024400000000000000840:010100000000000000000024400000000000001440:010100000000000000000020400000000000002240:010100000000000000000022400000000000002040:01010000000000000000001440000000000000
2440:010100000000000000000008400000000000002440:010100000000000000000024400000000000001C40:010100000000000000000024400000000000002040:010100000000000000000020400000000000002440:01010000000000000000001C400000000000002440}|{0.0470146,0.0380818,0.0300893,0.029149,0.029149,0.0249177,0.0249177,0.0230371,0.022567,0.022567,0.022567,0.022567,0.0211566,0.0211566,0.0188058,0.0188058,0.0169252,0.0164551,0.0164551,0.0164551,0.0164551,0.015985,0.015985,0.015985,0.015985,0.0145745,0.0145745,0.0136342,0.0136342,0.0122238,0.0122238,0.0117536,0.0117536,0.0117536,0.0117536,0.0117536,0.0108134,0.0108134,0.0103432,0.0103432,0.0103432,0.0103432,0.00846262,0.00846262,0.00799248,0.00799248,0.00752233,0.00752233,0.00752233,0.00752233,0.00752233,0.00752233,0.00752233,0.00705219,0.00705219,0.00611189,0.00611189,0.00611189,0.00611189,0.0051716,0.0051716,0.0051716,0.0051716,0.00470146,0.00470146,0.00423131,0.00423131,0.00423131,0.00376117,0.00376117,0.00376117,0.00376117,0.00329102,0.00329102,0.00329102,0.0032
9102,0.00282087,0.00282087,0.00282087,0.00282087,0.00235073,0.00235073,0.00188058,0.00188058,0.00188058,0.00188058,0.00188058,0.00141044,0.00141044,0.00141044,0.00141044,0.00141044,0.00141044,0.000940292,0.000940292,0.000940292,0.000940292}|{010100000000000000000024400000000000002240:010100000000000000000024400000000000002440:010100000000000000000022400000000000002440}|0.321087|||
selectivity_00|2127
selectivity_01|1068
selectivity_02|actual|0.502
Summary of changes:
NEWS | 4 +-
postgis/gserialized_estimate.c | 65 ++++++++++++++++++-------------
raster/rt_pg/rtpostgis_drop.sql.in | 2 +-
regress/core/regress_selectivity_expected | 2 +-
4 files changed, 42 insertions(+), 31 deletions(-)
hooks/post-receive
