[postgis-tickets] [PostGIS] #4739: st_dwithin : no spatial operator found
trac at osgeo.org
Fri Oct 2 03:50:54 PDT 2020
Reporter: grantfin | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.0
Component: postgis | Version: 3.0.x
Resolution: | Keywords:
Comment (by ansel):
A customer of us stumbled about the same issue in the context of
materialized views. While all objects are fully schema qualified by
the user, postgis itself nevertheless performs a non-schema-qualified
lookup of st_dwithin in this context.
The problem is serious because recent versions of pg_restore force the
search_path to empty for securty reasons. So while one can work
around this issue by setting search_path with normal sessions it's not
possible to do that during a restore from backup, leading to
pg_restore failures if postgis functions are part of index expressions
or materialized views despite them being fully schema-qualified.
Here's a testcase that demonstrates the problem in materialized views.
Putting the postgis schema into search_path will make the example work
but yield a database that cannot be successfully dumped and restored:
create database regression;
\c regression
create extension postgis schema postgis;
create schema postgis;
create table t gist (c postgis.geometry);
create index on t using gist (c);
select 1 from t where
postgis.st_dwithin(postgis.st_geomfromtext('POINT(3373062 5626876)'::text,
31467), c, 1000.);
The unqualified lookup appears to happen via postgis_index_supportfn in
this context:
(gdb) bt
#0 postgis_oid (typ=typ at entry=GEOMETRYOID) at lwgeom_pg.c:96
#1 0x00007fb139a031b3 in get_strategy_by_type (index=1, first_type=16498)
at gserialized_supportfn.c:382
#2 postgis_index_supportfn (fcinfo=<optimized out>) at
gserialized_supportfn.c:385
#3 0x00005631d50ccd2d in FunctionCall1Coll (flinfo=0x7ffe158edd00,
collation=<optimized out>, arg1=<optimized out>) at
./build/../src/backend/utils/fmgr/fmgr.c:1140
#4 0x00005631d50cd535 in OidFunctionCall1Coll (functionId=<optimized
out>, collation=collation at entry=0, arg1=arg1 at entry=140729260105088) at
./build/../src/backend/utils/fmgr/fmgr.c:1418
An ad-hoc fix that made the dump restorable was injecting the
following statement between --section=data and --section=post-data
during the restore.
alter function postgis.postgis_index_supportfn set search_path = postgis;
Not sure if adding this to the extension control file is the best fix
though: Maybe making postgis_index_supportfn look in which schema it
resides and using the same to find to qualify the postgis function
lookup is a better way?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4739#comment:2>
